Dissable ef0
Dissable ef0
Unread postby uunix » Sat Jan 21, 2017 7:38 am
Can someone remind me please how to stop/disable the inbuilt (or any) network card.
I've just done a fresh install, and ef0 is causing issues since I have tg0 enable as primary.
The error message on boot up is, Cannot configure ef0 as IRIS.blah.blah.
Cheers.
Re: Dissable ef0
Unread postby Raion-Fox » Sat Jan 21, 2017 8:56 am
ifconfig ef0 down
Re: Dissable ef0
Unread postby uunix » Sat Jan 21, 2017 9:53 am
Raion-Fox wrote:ifconfig ef0 down
Thanks Raion-Fox
That did cross my mind, but couldn't recall if it was permanent.
Anyway, back home now.
Re: Dissable ef0
Unread postby foetz » Sat Jan 21, 2017 10:27 am
ifconfig is not permanent. if you wanna change or disable something for good edit /etc/config/netif.options
Re: Dissable ef0
Unread postby Raion-Fox » Sat Jan 21, 2017 3:10 pm
Oh, I see. Apologies for the answer that wasn't helpful - foetz is right here.
Re: Dissable ef0
Unread postby uunix » Sat Jan 21, 2017 4:34 pm
foetz wrote:ifconfig is not permanent. if you wanna change or disable something for good edit /etc/config/netif.options
Thanks foetz, unfortunately although it worked, it did not solve the overall problem. Anyhow, I have now turned off all my SGI machines at home and at work because if I don't stop dicking about with weird things I will never get my paid for project out, so I will look into it in a few months when I turn them back on. :cry:
Y888099
Re: Dissable ef0
Unread postby Y888099 » Sun Jan 22, 2017 2:52 am
uunix wrote:I have now turned off all my SGI machines at home and at work because if I don't stop dicking about with weird things I will never get my paid for project out
LoL :lol:
khalidschofield
Re: Dissable ef0
Unread postby khalidschofield » Sun Jan 22, 2017 4:36 am
Know the feeling..... HPUX is my new obsession while trying to pick through a mountain of work
Re-install with OpenBSD :)
