Problem with new drive on Indigo
jammaster
Unread postby jammaster » Sat Dec 10, 2016 6:49 am
Hello!
I reinstall my second Indigo R3K.
I have put a fresh ST12550N 2.5GB 7200 disk on the first bay.
This drive is empty and seeable on my RS6000.
The problem is with the fx.IP12 utility.
the console say: can't read sgi label on disk.
It's normal cause the disk is empty... But
creating default bootinfo
creating default partitions
creating default volume directory ... all this posted on screen and ok.
Usually, it turn on the menu screen but here, NOTHING.
The console is bricked with a green bar (bug).
The keyboard is working (vernum led ... cap lock).
The disk ID is 1 (not 0) and in standard jumper configuration (term power from drive).
the disk is correctly posted on HINV -V ( dksc(0,1,8))
When i switch my termination jumper, the scsi bus seem to be corrupted (all scsi devices posted on hardware inventory ... bug?)
My other disk work fine!
A partitioning problem?
Is it a problem already treated and "childish"?
.......... :Onyx2: ............................... :Indigo2IMP: ..................................... :Indigo2: ........................... :Indigo: .............
IR2E 6GB 4x400Mhz .... MAXImp/4MB 512MB 195Mhz .... Extreme 384MB 250Mhz....Elan 64MB R3K ....
............. :Indy: ................................. :Octane2: .................
XS24 256MB 150 Mhz R5K .... V12 2GB 2x600Mhz ....
Intergraph TDZ2000 GL2 4110GT 1GB 2x600Mhz ... HP Visualize X-Class FX10 4GB 2x1000Mhz ... IBM 5160 V20, 8087 30Mb ... IBM 5162 10Mhz, 287XL, 6Mb, ST-4096 ... APPLE PowerMAC 9600/300 ... APPLE Quadra 840AV ... APPLE PowerMAC G5 Quad ... DEC AlphaStation 255/300 PS40 ... DEC AlphaStation 500/333 PS51 ... IBM RS/6000 PowerStation 7012-320 + GT3i ... SUN SparcStation 20 256MB AG10-E 2xSM81 ... SUN Ultra 80 4x450Mhz ... Amiga 2000HD, ECS 2MB ... Intergraph InterPro 225 ... DEC AlphaServer 4100 4x533Mhz 2MB ... SUN V880 ... DEC Multia 233Mhz
jammaster
Re: Problem with new drive on Indigo
Unread postby jammaster » Mon Dec 12, 2016 4:01 am
Found myself.
My 5.3 installation CD seem to dislike the XS8 framebuffer.
sashIP12 and fx.IP12 work great with XS24 but brick my R3K with XS8 (!!!).
Unread postby dexter1 » Mon Dec 12, 2016 4:56 am
Okay, haven't seen that before. Weerd bug.
Good that you solved it by exchanging the GFX, but when you don't have any spare boards the only alternative way to initialize such a disk is by pulling the graphics card and execute sashIP12 and fx.IP12 via the serial console.
jammaster
Unread postby jammaster » Mon Dec 12, 2016 5:47 am
Yes, thank for the advice.
In add, i'm very lucky: My external sgi cdrom have a 512k jumper. It save my life with the IP12 for booting!
It remind my old RS/6000 POWER1 where you need to put the right floppy for the right framebuffer during maintenance mode for having something at screen!
