help for find my DVD on IRIX onyx4
jmjsgi
Unread postby jmjsgi » Wed Dec 07, 2016 1:03 pm
Hello,
I have a onyx4 ultimatevision with a DVD reader.
I would like test a fire version 7 on, but after installation the desktop change with a discreet interface.
With my root account I restarted the interface with "chkconfig desktop on"
I also restarted the media with "chkconfig mediad on".
Now, the icon of my DVD player does not appear anymore and I can no longer use my reader.
Can you help me ?
:O2+: :1600SW: SGI O2+ R12000 400 768mo and 36gb
:O2: :1600SW: :O2: O2 R5000 180 320 2x18gb
:Indy: Indy R5000 180mhz
:Indigo2IMP: Indigo2maximum impact R10000 195
:O3x0: ONIX4 4x800 8gb V12 150gb
:Tezro: TEZRO 4x1ghz
Re: help for find my DVD on IRIX onyx4
Unread postby dexter1 » Thu Dec 08, 2016 12:55 am
There should be a directory in your home folder with the name ~/.desktop-<manchinename> where machinename is your Onyx4 hostname. This directory will contain files and links to devices.
I usually check in other users .desktop directory if there are things missing. Perhaps making a new user and look for changes in that directory will reveal the link to the DVD player, so you can recreate it.
jmjsgi
Unread postby jmjsgi » Tue Dec 13, 2016 9:46 am
Hello,
Thank you dexter1, i go lookink the link in the folder desktop.
sgicollector
Unread postby sgicollector » Mon Feb 27, 2017 8:50 am
Or login as root, not the discreet mutant desktop setup
