Irix version
robbo007
Irix version
Unread postby robbo007 » Tue Nov 01, 2016 9:41 am
Hi all,
I've just obtained a Octane 2 workstation with Irix all ready installed. name -a says
IRIX64 6.5 04091957 IP30 Is this the latest version I can install on this machine? If not whats the latest version. I guess its not available to upgrade right?
Thanks,
Rob
Re: Irix version
Unread postby uunix » Tue Nov 01, 2016 9:53 am
Try uname -Ra
6.5.30 is the last.
Dodoid
Re: Irix version
Unread postby Dodoid » Tue Nov 01, 2016 1:58 pm
If it's not the latest, newer ones can be acquired online and burnt to discs with CDBurnerXP but you might need an external SCSI CD drive as the Octane 2 doesn't have one built in.
and a small army of Image
robbo007
Re: Irix version
Unread postby robbo007 » Wed Nov 02, 2016 1:08 am
ok great thanks. Will I have to do a complete reinstall? Or can I upgrade somehow?
Re: Irix version
Unread postby vishnu » Wed Nov 02, 2016 9:12 am
robbo007 wrote:ok great thanks. Will I have to do a complete reinstall? Or can I upgrade somehow?
Depending on what version you have you can usually upgrade with the so-called "overlay" CDs, what does uname -Ra tell you?
robbo007
Re: Irix version
Unread postby robbo007 » Thu Nov 03, 2016 3:55 pm
IRIX64 octane2 6.5 6.5.20m 04091957 IP30
Re: Irix version
Unread postby vishnu » Thu Nov 03, 2016 4:07 pm
robbo007 wrote:IRIX64 octane2 6.5 6.5.20m 04091957 IP30
The "m" in 6.5.20m indicates that your Octane has followed the "maintenance" upgrade stream, as opposed to the "feature" stream, but those streams were joined in either 6.5.21 or 22 (can't remember which). The overlay to upgrade to 6.5.21 was a free download when techpubs was still alive, presumably one of the many mirrors that our local members have established will have that download available...
Dodoid
Re: Irix version
Unread postby Dodoid » Thu Nov 03, 2016 4:51 pm
Pretty sure 6.5.22m exists because old machines like the Indigo2 can run 6.5.22m but not 6.5.22f or anything newer. I had an older IRIX version than that (6.5.14 I think) on my O2 and was able to upgrade to 6.5.30 using overlay discs and software manager.
Apperantly I'm super wrong, I forget where I read that, ignore this post.
Re: Irix version
Unread postby foetz » Thu Nov 03, 2016 5:17 pm
Dodoid wrote:Pretty sure 6.5.22m exists because old machines like the Indigo2 can run 6.5.22m but not 6.5.22f or anything newer
the maintenance and feature streams do not depend on specific hardware. the difference is that the feature stream has additional, well, features :P
it was more expensive and shipped with one additional cd.
Dodoid
Re: Irix version
Unread postby Dodoid » Thu Nov 03, 2016 5:55 pm
Huh, I read that somewhere but they must have been wrong. Edited post to say it was wrong.
Re: Irix version
Unread postby foetz » Thu Nov 03, 2016 7:03 pm
Dodoid wrote:Huh, I read that somewhere but they must have been wrong. Edited post to say it was wrong.
no prob at all. usually it's a good idea to keep in mind that the vast majority on the internet is at least partially wrong or incomplete. especially in case of non-mainstream stuff.
for the sake of completeness, starting from 6.5.23 feature and maintenance were the same. you could still switch for compatibility reasons but there was no difference otherwise anymore.
robbo007
Re: Irix version
Unread postby robbo007 » Fri Nov 04, 2016 2:07 am
Thanks for the info. I managed to locate images of 6.5.30 and burnt them to cd's. The question will it work? 3 of the cd images where named: Installation tools and Overlays 1, 2, 3 the others are labelled Applications and Complementary Applications. I'm going to source a CDROM drive of eBay as this model does not have one. I see there internal y external options. Can I use the harddrive bays to conenct the cdrom?
Dodoid
Re: Irix version
Unread postby Dodoid » Fri Nov 04, 2016 4:22 am
robbo007 wrote:Thanks for the info. I managed to locate images of 6.5.30 and burnt them to cd's. The question will it work? 3 of the cd images where named: Installation tools and Overlays 1, 2, 3 the others are labelled Applications and Complementary Applications. I'm going to source a CDROM drive of eBay as this model does not have one. I see there internal y external options. Can I use the harddrive bays to conenct the cdrom?
Unfortunately, the Octane's hard drive bays are the wrong size for a CD-ROM. You will need an external SCSI one, unless there is some other method I'm not aware of.
Re: Irix version
Unread postby jan-jaap » Fri Nov 04, 2016 4:30 am
Dodoid wrote:some other method I'm not aware of.
Network installation. But if this is your first IRIX installation I'd advise against that. Too many things that can go wrong.
robbo007
Re: Irix version
Unread postby robbo007 » Fri Nov 04, 2016 4:53 am
This will be my first. I've done loads of Solaris, Unix etc but Irix seem very different :) I've just found my original unopened floppy disks and users manual. I think I should read through it :)
