Trying to install Supertux. libtiff.so.3 not found strikes again!
Dodoid
Unread postby Dodoid » Wed Oct 05, 2016 3:02 pm
Trying to install Supertux on 6.5.30. Downloaded and installed all dependencies using nekodeps.pl. tiff installed normally, as expected. However, when I attempt to run Supertux, it requires libtiff.so.3. /usr/nekoware/lib/libtiff.so.3 is there, but it is a symlink to /usr/nekoware/lib/libtiff.so.6. Specifically, Supertux wants version "sgi3.7", which 6.0 presumably is not. Does anyone have a copy of the real libtiff.so.3, or know how to make it work with libtiff.so.6.0?
and a small army of Image
necron2600
Re: Trying to install Supertux. libtiff.so.3 not found strikes again!
Unread postby necron2600 » Wed Oct 05, 2016 8:43 pm
libtiff3.tar
libtiff.so.3.8
(580 KiB) Downloaded 19 times
I ended up placing a bunch of older libs in /opt/lib32/ and adding that to my lib path for many other pieces of software:
$ ls /opt/lib32/
libFLAC++.so.7.0 liblber-2.3.so.1.14 libtheoradec.so.2.4
libFLAC.so.5 libldap-2.3.so.1.14 libtiff.so.3
libcurl.so.4 liblzo2.a libtiff.so.3.8
libgcc_s.so.1 liblzo2.la
libguile-ltdl.so.2.0 libstdc++.so.7
libguile.so.13.0 libtheoradec.so.2
My supertux install works fine (with libtiff.so.3.8 in library path), except for sound. its all hissing instead of proper sound.
