GIMP install problem neko_lcms.sw.jpeg (solved)
cinenate35
Unread postby cinenate35 » Sun Oct 02, 2016 10:58 am
Hey Folks,
I am trying to install GIMP . I've got all of nekoware on my box and I can not resolve the depeneincies for "neko_lcms.sw.jpeg" and "neko_lcms.sw.tiff". The only item in nekoware is "neko_lcms.sw" and I've already installed that. Nothing. It is always asking for those two items. Am I missing something here? :?
Thanks!
Nate
:Octane2: :O2: :O2:
Re: GIMP install problem neko_lcms.sw.jpeg
Unread postby dexter1 » Mon Oct 03, 2016 12:50 am
Try one of the older lcms packages in obsolete/archive:
http://nekoware.bufferoverflow.xyz/obso ... 14.tardist is the previous version we made.
Chances are that you also need to install previous versions of tiff 3.x and jpeg in that same. Try http://nekoware.bufferoverflow.xyz/obso ... .2.tardist and http://nekoware.bufferoverflow.xyz/obso ... 6b.tardist
cinenate35
Re: GIMP install problem neko_lcms.sw.jpeg (solved)
Unread postby cinenate35 » Mon Oct 03, 2016 7:42 am
Thanks, dexter1! That solved the issue. Have a good day!
Nate
:Octane2: :O2: :O2:
