Nedit with tabs ?
radiance
Nedit with tabs ?
Unread postby radiance » Thu Sep 22, 2016 2:42 am
Hi,
found this older thread: viewtopic.php?f=7&t=3119&start=15
It talks about Nedit 5.5RC1 for irix which should support tabs... (like a modern browser)
Unfortunately the links to the binary in that forum post are dead...
Does anyone know where I can fetch some src or a binary of nedit with tabs?
If not, does anyone recommend a text editor with syntax colouring/highlighting and tabs ? (for coding C/C++)
Many Thanks ;)
Terrence
Re: Nedit with tabs ?
Unread postby foetz » Thu Sep 22, 2016 3:09 am
radiance
Unread postby radiance » Thu Sep 22, 2016 4:11 am
foetz -> thanks a lot :) i really appreciate your help :)
Thanks,
Terrence
