spacemouse spaceball, app side
Re: spacemouse spaceball, app side
Unread postby uunix » Thu May 26, 2016 7:58 am
Titox
Unread postby Titox » Fri May 27, 2016 9:08 am
Links from 3DConnexion website are working for me, but I must be logged to get it.
No SDK tought, as I'm not registered as developer on that website.
http://www.f3b.es
http://unixverse.blogspot.com
Unread postby uunix » Sat Jun 04, 2016 3:58 am
uunix wrote:Link is broken for me also.
I see this http://www.ebay.co.uk/itm/Hewlett-Packard-4000FLX-Spaceball-Controller-/222117045649?hash=item33b7352591:g:qH8AAOSwDuJW2JRH
Not Labtec though. I am liking it.
I bought it.. it sits on my desk.. and looks damn cool! But that's as far as I have got.
Unread postby uunix » Sat Jun 04, 2016 5:02 am
It does beep when I start up computer, also beeps when starting up SMOKE, and attached to the serial port no problem.. but does nothing that I am aware off.
Unread postby uunix » Sat Jun 04, 2016 6:12 am
ivelegacy wrote:oh, I don't have CATIA or Pro/E, therefore I can't confirm ='(
I have Pro/E but it's on my INDIGO, hence I'd need some serial adapter changer.. which now I come to thing about it I do have, but it would mean the cables would end up being 50 miles long!
Once I have sorted out my desk system at home, I'd like to bring my INDIGO home (it is my favourite-ish).
jpstewart
Unread postby jpstewart » Sat Jun 04, 2016 7:47 am
uunix wrote:It does beep when I start up computer, also beeps when starting up SMOKE, and attached to the serial port no problem.. but does nothing that I am aware off.
Have you run the confidence tests (from Tool Chest)? It has tests for the spaceball that will tell you if the hardware works and is correctly set up under IRIX.
HP C8000
Digital DECstation 5000/125
Unread postby uunix » Tue Jun 28, 2016 3:40 pm
Downloaded drivers for Spaceball 4000 - Motion Control Centre (MCC) version 4.64
Something though needs translating, it's 45 degrees off how it should be positioned in my hand.
Unread postby uunix » Fri Jul 08, 2016 4:43 pm
Well this explains why it's 45 degrees out..
http://www.ebay.co.uk/itm/4000FLX-IBM-33L3251-Spaceball-4000-FLX-33L3253-33L3251-Motion-Controller-Mouse-/311650187677?hash=item488fcc799d:g:ZVIAAOxy0aBRo3~F
Or rather not..
Mine is missing the part on the left, so it works fine. I just had it positioned incorrectly.
Now, I have drivers for Maya 5, I wonder can I get it working in Maya 6.5? There seems no options fro within Maya to use this, but just maybe a config file change or something may solve this.
I will let you know what I find.
