neko_pgsql-8.3.1 bug/suggestion
duck
Unread postby duck » Fri Feb 12, 2016 6:43 am
My octane started pausing every time I shut it down until I pressed enter and I narrowed it down to the init.d scripts neko_pgsql-8.3.1 installs; even if you're not running the server, it will still try to shut it down using su - $PGUSER -c [...] and the unprivileged user that it also sets up does have a password (*LK*, lock?) causing su to prompt for input.
I would suggest something like
--- neko_pgsql.old      Fri Feb 12 16:29:42 2016
+++ neko_pgsql  Fri Feb 12 16:27:53 2016
@@ -42,6 +42,8 @@
 # Who to run the postmaster as, usually "postgres".  (NOT "root")
 PGUSER=postgres
+PGPID="${PGDATA}/postmaster.pid"
 # Where to keep a log file
 PGLOG="$PGDATA/server.log"
@@ -82,9 +84,11 @@
         fi
   stop)
-        echo -n "Stopping PostgreSQL: "
-        su - $PGUSER -c "$PGCTL stop -D '$PGDATA' -s -m fast"
-        echo "ok"
+       if [ -e $PGPID ];then
+         echo -n "Stopping PostgreSQL: "
+         su - $PGUSER -c "$PGCTL stop -D '$PGDATA' -s -m fast"
+         echo "ok"
+       fi
   restart)
         if $IS_ON $PROG; then
To prevent trying to shut down a server that isn't running at least.
___(o)=
\____)
