Playing youtube over RDP is sluggish.. but you can zoom in on irix
necron2600
Unread postby necron2600 » Wed Feb 03, 2016 2:26 pm
Ok, I figure I can share a new tidbit I started to use while working with an SGI/IRIX as a daily system. I do everything on it, but some things I have to remote desktop into a windows system for (using seamlessrdp so it looks native to IRIX desktop) .. MS word for docx files, Powerpoint, and Skype.
However, Youtube is something that I may waste my life away on that is very poor for viewing over an RDP connection (especially with a 100 gigabit NIC on an Octane with 1920x1200 resolution so images are even smaller). A youtube video does go smoothly if it is reduced to a very small window on the windows desktop. But that becomes too small for me .. and hard to make details out.
Well, it may be a hacky way to do it, but I use the irix command "oglsnoop" to zoom in on the youtube window. I make oglsnoop's window as wide as possible and zoom out several times so the youtube window fits properly in the zoom window. If I had the youtube window in the remote desktop session enlarged to the same size, it would be like watching a slideshow. So at least now I can see a larger smoothly playing youtube video.
If anyone else knows of a better way, or even a better zoom ability in IRIX, i'm all ears.
Reason: merged
toasty
Re: Playing youtube over RDP is sluggish.. but you can zoom in on irix
Unread postby toasty » Wed Feb 03, 2016 3:12 pm
Looks pretty cool. But if you want to watch youtube vids natively on IRIX, there is a way! Get neko_youtube_dl from beta (neko_python required) and run
youtube-dl -U
as root to update the script to the latest version. Then just download a video and play it with neko_mplayer.
With VPro graphics, run
youtube-dl -f 18 "URL"
to download a 640x360 mp4 video. Make sure to use the vo=gl option in mplayer otherwise it will be scrambled.
On slower systems (even on an O2), use
youtube-dl -f 36 "URL"
to download a 320x180 video.
You can also use the updated youtube-dl script to download music from soundcloud onto your SGI.
This might be common knowledge for some of you already but thought I'd share.
Past: :Fuel: :Octane2: :O2: :O2: :O2: :Indy: Present: MacBook
