josehill wrote:
On UNIX systems, users are actually tracked by the system by their UID, which is a number, and not by username. UIDs are set in /etc/password (the third field in the colon delimited file), and the id command gives you details via the command line.
thanks jose!! geez why i forgot about this, i used this when setting up SFU on my WinXP
thanks again and already utilized it
checking at the passwd file on both system, there were three difference:
root = password field (not necessary)
nobody = octane has 60001 UID and GID; while o2 has -2 UID and GID
geo = my user name which only exist on my octane
ok my questions are:
* should GID also be the same as possible? or just the UID is enough?
* should i create geo on my o2 to have it the same as my octane?
* which one should i use for nobody, 60001 or -2?
hamei wrote:
All the way up to where they stop, in some cases
About the boobs, proper identification is a skill to be developed through long and arduous study, grasshopper. The giveway is motion. The big bra, small boobs disguise does not swing and sway properly. Neither does the foam rubber system. Only the True Example will correctly jiggle, jounce, and in the best cases, float rythmically from side to side. Observe them on a walking carrier, that's the best training.
hahaha indeed
wow! nice info hamei! will keep that in mind hehe but geez good for you there still got those bouncing balls around, here? most have "airport" as they call it here hehe really waste of beautiful faces, just don't have the bumpers, if only have, perfect!
(Sakura)
(Sasuke)
(Naruto) ... lil Jesse! (O2 laptop)
