Developer Toolbox and gmemusage
cris_adder
Unread postby cris_adder » Fri May 11, 2012 3:33 am
Just trying to track down the source code for gmemusage to compile on Irix 5.3. The link below suggests the following:
http://www.auscert.org.au/render.html?it=183
Developer Toolbox versions 6.0 (based on IRIX 5.3) and 6.1 (based on
IRIX 6.2) contain the gmemusage program and source code.  With the
Developer Toolbox, the gmemusage program can be installed wherever
desired and on any IRIX version 5.x through 6.4.
I have found the source at a few places, but it seems to be a modified version for Linux... so just wanted to ask if someone could check if the source on Developer Toolbox V6.0 is the same as the Linux modified version below.
gmemusage.c.txt
(21 KiB) Downloaded 18 times
gmemusage-0.2.tar.gz
(16.65 KiB) Downloaded 53 times
Thanks...
cris_adder
Re: Developer Toolbox and gmemusage
Unread postby cris_adder » Sat May 12, 2012 6:08 am
The above source files are definitely Linux, was able to compile the code, but when it runs it tries to make some Linux specific calls like reading the file "/proc/kcore", but of course exists as it does not exist in Irix 5.3.
So was hoping that someone might be able to help with the source code for gmemusage from one of those Developer Tooklkit CDs and let me know the changes to be made...
Thanks...
 * Cheap way to get amount of installed mem in the computer -- get size of
 * /proc/kcore.
   if ( stat ( "/proc/kcore" , &s ) < 0 )
      fprintf ( stderr , "%s: cannot stat /proc/kcore" , progname ) ;
      perror ( "" ) ;
      exit ( 1 ) ;
   sysmem = s . st_size ; /* in Kilobytes */
 * Read /proc/meminfo to get usable memory and buffers. Presumably buffers
 * should be considered a part of the kernel memory.
   if ( ( meminfo = fopen ( "/proc/meminfo" , "r" ) ) == NULL )
      fprintf ( stderr , "%s: cannot open /proc/meminfo" , progname ) ;
      perror ( "" ) ;
      exit ( 1 ) ;
   while ( fgets ( buf , sizeof ( buf ) , meminfo ) )
      if ( !strncmp ( buf , MemLine , MemLineLen ) )
    /* Mem: total used free shared buffers cached */
    sscanf ( buf , "%*s %d %*d %d %*d %d" , &totalmem , &freemem ,
        &buffermem ) ;
    break ;
   sysmem /= 1024 ;
   totalmem /= 1024 ;
   freemem /= 1024 ;
   buffermem /= 1024 ;
   kernelmem = sysmem - totalmem ;
   fclose ( meminfo ) ;
   return ;
Unread postby jan-jaap » Sat May 12, 2012 2:13 pm
There. Hope it doesn't violate forum rules -- then again, until a couple of years it was freely downloadable from sgi.com ...
This is from DT 6.1, disc 3/3
gmemusage.tar.gz
(68.47 KiB) Downloaded 57 times
