It is currently Fri May 24, 2013 4:04 am
Post new topic Reply to topic  [ 25 posts ]  Go to page 1, 2  Next
Unread postPosted: Fri Jan 06, 2012 8:09 am
Code:
firefox
 1670:/usr/nekoware/lib/firefox-2.0.0.22pre/firefox-bin: rld: Fatal Error: attempted access to unresolvable symbol in /usr/nekoware/lib/firefox-2.0.0.22pre/firefox-bin: sqlite3_enable_shared_cache
root@[tezro]:~/# ldd /usr/nekoware/lib/firefox-2.0.0.22pre/firefox-bin
 1671: 01:27:47 /usr/nekoware/lib/firefox-2.0.0.22pre/firefox-bin: rld: Fatal Error exit/longjmp: Cannot Successfully map soname 'libsmime3.so' under any of the filenames ../../dist/bin/libsmime3.so:/usr/nekoware/lib/libsmime3.so:/usr/apple/shake3.5//lib//libsmime3.so:/usr/lib32/libsmime3.so:/usr/lib32/internal/libsmime3.so:/lib32/libsmime3.so:/opt/lib32/libsmime3.so:
 1671:/usr/nekoware/lib/firefox-2.0.0.22pre/firefox-bin: rld: Fatal Error: Cannot Successfully map soname 'libsmime3.so' under any of the filenames ../../dist/bin/libsmime3.so:/usr/nekoware/lib/libsmime3.so:/usr/apple/shake3.5//lib//libsmime3.so:/usr/lib32/libsmime3.so:/usr/lib32/internal/libsmime3.so:/lib32/libsmime3.so:/opt/lib32/libsmime3.so:
Uninstall SQ Lite 3 and Python module sql lite 3 and problem goes away.
I was in as root to do admin and install/remove software.
Please check that you do no break other packages when you create nekoware.
I have not found any reference to this in the forums but I guess it is self evident for most developers.
I haven't seen any nekoware updates lately and I think the problem has existed for a while now.
R.
死の神はりんごだけ食べる
アレゲはアレゲ以上のなにものでもなさげ -- アレゲ研究家
Unread postPosted: Fri Jan 06, 2012 12:55 pm
Yep, been a known issue for quite a while: viewtopic.php?f=7&t=16724316
Unread postPosted: Fri Jan 06, 2012 1:37 pm
Thanks nekonoko. I failed to find that in my search before posting. At least there is another link back to the original topic now.
R.
死の神はりんごだけ食べる
Unread postPosted: Sun Jan 08, 2012 6:21 am
I was thinking ... (danger, Will Robinson. Danger ! Danger !) When a package is known to be bad, would it be better to ditch it entirely or to create a "known bad" directory it could be moved to so that maybe other people wouldn't have to start from scratch when packaging problem-child applications ?
Unread postPosted: Sun Jan 08, 2012 1:10 pm
I think it might be okay if you are doing SQL lite stuff in isolation. Might be better if people can find the answers easily.. It breaks firefox which includes everything including the kitchen sink. Modern software .. if it aint got a dozen depndancies... I don't know why my previous search was unsuccessful.
Keywords: SQL Lite 3, firefox firefox-bin rld: Fatal Error sqlite3_enable_shared_cache unresolvable symbol
R.
死の神はりんごだけ食べる
Unread postPosted: Fri Jan 27, 2012 6:23 am
Just built SQlite 3.07.10 and installed it. Held my nose, put my right foot in the garbage can, hopped around in a circle widdershins three times and restarted Fireflop : FF didn't crash. Posting from there now.
So maybe whatever was wrong with SQLite 3 has been fixed ?
Unread postPosted: Sat Jan 28, 2012 12:44 pm
neko_sqlite3-3.7.10.tardist is in /incoming - it works for me with nekoware firefox.
Unread postPosted: Mon Jan 30, 2012 1:22 pm
I've moved it to /beta; thanks!
Unread postPosted: Mon Feb 27, 2012 6:40 pm
This didn't seem to fix it for me. Now it's attempted access to a new unresolvable symbol (sqlite3_os_switch).
:Crimson: :Onyx: :O2000: :O200: :O200: :PI: :Indigo: :Indigo: :Indigo: :Octane: :O2: :1600SW: :Indigo2: :Indigo2: :Indigo2IMP: :Indigo2IMP: :Indy: :Indy: :Indy: :Cube:
Unread postPosted: Tue Feb 28, 2012 2:16 pm
Which version of firefox are you using, and do you have any LD_LIBRARY_PATH (possibly with N32 somewhere) set (you shouldn't, any nekoware package that requires it is broken and should be fixed)?
Unread postPosted: Wed Feb 29, 2012 12:42 pm
Attempting to run 2.0.0.22 which I believe is the latest on the nekoware mirror and everything should be running at defaults. It seems that the same problem is affecting Thunderbird as well.
Unread postPosted: Wed Feb 29, 2012 2:28 pm
Please post the output of
Code:
ls -l /usr/nekoware/lib/libsqli*
LD_LIBRARYN32_PATH=/usr/nekoware/lib/firefox-2.0.0.22pre ldd /usr/nekoware/lib/firefox-2.0.0.22pre/firefox-bin
LD_LIBRARY_PATH=/usr/nekoware/lib/firefox-2.0.0.22pre ldd /usr/nekoware/lib/firefox-2.0.0.22pre/firefox-bin
Then try
Code:
LD_LIBRARY_PATH=/usr/nekoware/lib/firefox-2.0.0.22pre /usr/nekoware/lib/firefox-2.0.0.22pre/firefox-bin
Unread postPosted: Wed Feb 29, 2012 6:56 pm
I have to do this through IRC because I can't post here through Netscape so expect some weird formatting.
Code:
 $ ls -l /usr/nekoware/lib/libsqli*
<Peanut> -rw-r--r--    1 root     sys       1908772 Feb 27 18:21 /usr/nekoware/lib/libsqlite3.a
<Peanut> -rwxr-xr-x    1 root     sys           861 Feb 27 18:21 /usr/nekoware/lib/libsqlite3.la
<Peanut> lrwxr-xr-x    1 root     sys            17 Mar  2  2011 /usr/nekoware/lib/libsqlite3.so -> libsqlite3.so.1.6
<Peanut> lrwxr-xr-x    1 root     sys            17 Mar  2  2011 /usr/nekoware/lib/libsqlite3.so.1 -> libsqlite3.so.1.6
<Peanut> -rwxr-xr-x    1 root     sys       1391944 Feb 27 18:21 /usr/nekoware/lib/libsqlite3.so.1.6
Code:
$ ldd /usr/nekoware/lib/firefox-2.0.0.22pre/firefox-bin
<Peanut>         libm.so  =>      /usr/lib32/libm.so
<Peanut>  1708: 18:42:43 /usr/nekoware/lib/firefox-2.0.0.22pre/firefox-bin: rld: Fatal Error exit/longjmp: Cannot Successfully map soname 'libsmime3.so' under any of the filenames ../../dist/bin/libsmime3.so:/usr/nekoware/lib/libsmime3.so:/usr/lib32/libsmime3.so:/usr/lib32/internal/libsmime3.so:/lib32/libsmime3.so:/opt/lib32/libsmime3.so:
<Peanut>  1708:/usr/nekoware/lib/firefox-2.0.0.22pre/firefox-bin: rld: Fatal Error: Cannot Successfully map soname 'libsmime3.so' under any of the filenames ../../dist/bin/libsmime3.so:/usr/nekoware/lib/libsmime3.so:/usr/lib32/libsmime3.so:/usr/lib32/internal/libsmime3.so:/lib32/libsmime3.so:/opt/lib32/libsmime3.so:
Code:
$  LD_LIBRARYN32_PATH=/usr/nekoware/lib/firefox-2.0.0.22pre ldd /usr/nekoware/lib/firefox-2.0.0.22pre/firefox-bin
<Peanut>         libsmime3.so  =>         /usr/nekoware/lib/firefox-2.0.0.22pre/libsmime3.so
<Peanut>         libssl3.so  =>   /usr/nekoware/lib/firefox-2.0.0.22pre/libssl3.so
<Peanut>         libnss3.so  =>   /usr/nekoware/lib/firefox-2.0.0.22pre/libnss3.so
<Peanut>         libnssutil3.so  =>       /usr/nekoware/lib/firefox-2.0.0.22pre/libnssutil3.so
<Peanut>         libsoftokn3.so  =>       /usr/nekoware/lib/firefox-2.0.0.22pre/libsoftokn3.so
<Peanut>         libXt.so  =>     /usr/lib32/libXt.so
<Peanut>         libsqlite3.so  =>        /usr/nekoware/lib/libsqlite3.so
<Peanut>         libxpcom_compat.so  =>   /usr/nekoware/lib/firefox-2.0.0.22pre/libxpcom_compat.so
<Peanut>         libmozjs.so  =>  /usr/nekoware/lib/firefox-2.0.0.22pre/libmozjs.so
<Peanut>         libxpcom.so  =>  /usr/nekoware/lib/firefox-2.0.0.22pre/libxpcom.so
<Peanut>         libxpcom_core.so  =>     /usr/nekoware/lib/firefox-2.0.0.22pre/libxpcom_core.so
<Peanut>         libplds4.so  =>  /usr/nekoware/lib/firefox-2.0.0.22pre/libplds4.so
<Peanut>         libplc4.so  =>   /usr/nekoware/lib/firefox-2.0.0.22pre/libplc4.so
<Peanut>         libnspr4.so  =>  /usr/nekoware/lib/firefox-2.0.0.22pre/libnspr4.so
<Peanut>         libpthread.so  =>        /usr/lib32/libpthread.so
<Peanut>         libdl.so  =>     /usr/lib32/libdl.so
<Peanut>         libgtk-1.2.so.1  =>      /usr/nekoware/lib/libgtk-1.2.so.1
<Peanut>         libgdk-1.2.so.1  =>      /usr/nekoware/lib/libgdk-1.2.so.1
<Peanut>         libgmodule-1.2.so.1  =>  /usr/nekoware/lib/libgmodule-1.2.so.1
<Peanut>         libglib-1.2.so.1  =>     /usr/nekoware/lib/libglib-1.2.so.1
<Peanut>         libintl.so.9  =>         /usr/nekoware/lib/libintl.so.9
<Peanut>         libXext.so  =>   /usr/lib32/libXext.so
<Peanut>         libX11.so.1  =>  /usr/lib32/libX11.so.1
<Peanut>         libsocket.so  =>         /usr/lib32/libsocket.so
<Peanut>         libfastm.so  =>  /usr/lib32/libfastm.so
<Peanut>         libCsup.so  =>   /usr/lib32/libCsup.so
<Peanut>         lib
<Peanut> libC.so.2  =>    /usr/lib32/libC.so.2
<Peanut>         libCio.so.1  =>  /usr/lib32/libCio.so.1
<Peanut>         libc.so.1  =>    /usr/lib32/libc.so.1
<Peanut>         libgen.so  =>    /usr/lib32/libgen.so   delay-load
<Peanut>         libintl.so.4  =>         /usr/nekoware/lib/libintl.so.4
<Peanut>         libiconv.so.3  =>        /usr/nekoware/lib/libiconv.so.3
Code:
$ LD_LIBRARY_PATH=/usr/nekoware/lib/firefox-2.0.0.22pre ldd /usr/nekoware/lib/firefox-2.0.0.22pre/firefox-bin
<Peanut>         libnspr4.so  =>  /usr/nekoware/lib/firefox-2.0.0.22pre/libnspr4.so   libpthread.so  =>        /usr/lib32/libpthread.so
<Peanut>         libC.so
<Peanut> ibC.so.2  =>    /usr/lib32/libC.so.2
Code:
$ LD_LIBRARY_PATH=/usr/nekoware/lib/firefox-2.0.0.22pre /usr/nekoware/lib/firefox-2.0.0.22pre/firefox-bin
<Peanut>  1716:/usr/nekoware/lib/firefox-2.0.0.22pre/firefox-bin: rld: Fatal Error: attempted access to unresolvable symbol in /usr/nekoware/lib/firefox-2.0.0.22pre/firefox-bin: sqlite3_os_switch
From what the folks on the IRC are telling me, either my hair is on fire or there is something missing from sqlite3 that everyone else somehow, possibly from files left over from upgrading an older version of sqlite still have, hence how they are not getting the same problem. sqlite3_os_switch was removed back in 3.5.0.
Unread postPosted: Wed Feb 29, 2012 9:32 pm
I talked with Pentium about this on IRC, and came to the conclusion that it's not a library path issue, but an issue with sqlite3_os_switch itself. That was an internal, undocumented function that was removed in the transition between 3.4.2 and 3.5.0 of SQlite. The call to sqlite3_os_switch was removed from Firefox sometime before 3.0, but it strongly appears that the .22pre version in nekoware still has the call.
Basically, I don't see how Firefox2 could possibly be working with sqlite above 3.4.2, since it relies on functions that are, quite simply, gone; Pentium's problem should affect anyone using Nekoware Firefox and the beta sqlite.
Altix 450 / 8x9030, 14x9040, 28x9140 (100 cores) / 200GB DDR2
Unread postPosted: Wed Feb 29, 2012 10:03 pm
pentium wrote:
Code:
Try (c shell or tcshell) :
Code:
urchin 10% setenv LD_LIBRARY_PATH /usr/nekoware/lib/firefox-2.0.0.22pre
urchin 11% /usr/nekoware/lib/firefox-2.0.0.22pre/firefox-bin
If I try to run it your way I get a bunch of error messages about missing "libsmime"
Quite possibly. But this sqlite version does permit fireflop to start and run and not crash. I have no idea if it actually does anything, but at least it doesn't blow up the 'flop ....
Edit : those useless assbreath Down's Syndrome poster children at Fireflop ... :evil:
http://aplawrence.com/Web/firefox-sqlite.html
tastes great, less filling !
http://downloadsquad.switched.com/2009/ ... databases/
Morons. Absolute useless godforsaken morons. Let's fix fireflop 2 for Irix and let the mouth-breathers run FF3+ ....
