orange wrote:
some help here would be greatly appreciated
Hi have you tried the silly things first ?
1) Can the Virtual box hosted Dina be contacted by another computer on the LAN ?
If you have no other machine other than the SGI, can dina ping out to
http://www.google.com ?
2) You''ve configured dina with an IP address yes ?
3) And turned off your existing DHCP server .. probably installed in your internet router ? (Dina is a DHCP server as well and you can't have 2 on the same LAN, and I think this is your problem)
4) Have you read :
http://www.sgidepot.co.uk/netboot.html a huge mine of information!
Assuming your dina guest can get out onto the LAN and you're sure people on the LAN can talk to it and any other DHCP server on the LAN is switched off, try :
1) Enter Maintenance and get to the Command monitor
2) Enter : setenv netaddr <IPaddressyouwantyourINDY2tohave>
3) Enter : boot -f bootp()<IPaddressofDina>:/irix/6.5/1/stand/fx.ARCS --x
That will hopefully get you to the disk partitioning phase
4) Exit out once you have done any disk stuff
5) Enter Maintenace and get to Command monitor
6) Click 2. Install System Software
7) Enter the IP address of the dina box as the Remote host
8 ) Enter "/irix/6.5/1/dist" as the remote directory
9) click the enter/go button
Does that do anything ? You can always jump straight to step 5 if you don;t want to repartition the disk.
And also read :
http://se.mirror.nekoware.net/SGI_relat ... ation.htmlI used a combination fo that page and Ians site to learn how to do it.
Good luck!
Mark
