irssi 0.8.13 n32
uridium
irssi 0.8.13 n32
Unread postby uridium » Sun Jul 12, 2009 4:49 am
Seems like it's been a while since anyone bothered to port irssi, so here's my attempt that sits in /opt/irssi-0.8.13 so as not to conflict with the 0.8.10a nekoware version. Left the build tree+source below so who ever the maintainer is (zero clue) might want to use it as a guide to go roll some .idb,.sw,.opt,.man and plonk it in /usr/nekoware.
http://deviate.fi/~uridium/irssi-0.8.13 ... ee.tar.bz2
http://deviate.fi/~uridium/irssi-0.8.13 ... sl.tar.bz2
http://deviate.fi/~uridium/irssi-0.8.13 ... 32.tar.bz2 (no SSL/IPV6)
Thanks to the #sgi guys (oz.org) for testing + constructive abuse.
build env:
IP32 R5k @180Mhz
RAM: 128mb
OS: 6.5.29f
Nekoware: -CURRENT as @12-JUL-2009
Al Boyanich
Re: irssi 0.8.13 n32
Unread postby nekonoko » Fri Jul 17, 2009 9:00 am
Very cool. I don't know that anyone maintains irssi in Nekoware anymore, but if anyone would like it updated I can do it.
uridium
Re: irssi 0.8.14 n32
Unread postby uridium » Tue Sep 15, 2009 11:15 pm
Hi. irssi 0.8.14 came out. Let champagne fall from the heavens .. etc. Soo.. same deal as before, here's my binaries. They sit in /opt/irssi-0.8.14 so they don't fudge-pack anything in the hallowed /usr/nekoware (as it should be! O.o!). Builds. here's the n32 binaries with ssl and ipv6 support. Seems to work for me. Took my 180mhz R5k O2 with 128MiB RAM ~2.5hrs to build clean once I un-boned the config scripts. Regan, if your reading, is there a .au mirror of nekochan or something local? Heck..I'll stick up on deviate.fi again and let ifreq cop the bandwidth :> *hugs ifreq* Again, thanks to oz.org #sgi guys for testing.
build env:
IP32 R5k @180Mhz
RAM: 128mb
OS: 6.5.29f
Nekoware: -CURRENT as @16-SEP-2009
http://deviate.fi/~uridium/irssi-0.8.14 ... sl.tar.bz2
http://deviate.fi/~uridium/irssi-0.8.14 ... ee.tar.bz2
Al Boyanich
uridium
Unread postby uridium » Sun Sep 20, 2009 6:10 pm
* Sound of crickets
So is anyone else actually trying this? Working? problems?
Al Boyanich
jade_angel
Unread postby jade_angel » Mon Sep 28, 2009 9:39 pm
Well, I can give it a whirl when I get back to the States in mid-November - but with the timing, that's at best mildly useful...
theodric
Unread postby theodric » Wed Sep 30, 2009 9:20 am
uridium wrote:* Sound of crickets
I am! I am!
O2 RM7k/6.5.30. I have not setup lib paths and crap so maybe that's why it's dying on me with this err:
eris 11% ../bin/irssi
 8977:../bin/irssi: rld: Error: unresolvable symbol in ../bin/irssi: PL_curpad
 8977:../bin/irssi: rld: Error: unresolvable symbol in ../bin/irssi: PL_sv_yes
 8977:../bin/irssi: rld: Error: unresolvable symbol in ../bin/irssi: PL_op
 8977:../bin/irssi: rld: Error: unresolvable symbol in ../bin/irssi: PL_tmps_floor
 8977:../bin/irssi: rld: Error: unresolvable symbol in ../bin/irssi: PL_tmps_ix
 8977:../bin/irssi: rld: Error: unresolvable symbol in ../bin/irssi: PL_stack_sp
 8977:../bin/irssi: rld: Error: unresolvable symbol in ../bin/irssi: PL_markstack_ptr
 8977:../bin/irssi: rld: Error: unresolvable symbol in ../bin/irssi: Perl_get_sv
 8977:../bin/irssi: rld: Error: unresolvable symbol in ../bin/irssi: PL_perl_destruct_level
 8977:../bin/irssi: rld: Error: unresolvable symbol in ../bin/irssi: PL_sigfpe_saved
 8977:../bin/irssi: rld: Error: unresolvable symbol in ../bin/irssi: PL_sv_undef
 8977:../bin/irssi: rld: Error: unresolvable symbol in ../bin/irssi: PL_errgv
 8977:../bin/irssi: rld: Error: unresolvable symbol in ../bin/irssi: PL_stack_max
 8977:../bin/irssi: rld: Error: unresolvable symbol in ../bin/irssi: PL_stack_base
 8977:../bin/irssi: rld: Error: unresolvable symbol in ../bin/irssi: PL_markstack_max
 8977:../bin/irssi: rld: Error: unresolvable symbol in ../bin/irssi: PL_na
 8977:../bin/irssi: rld: Error: unresolvable symbol in ../bin/irssi: Perl_sv_2pv_flags
 8977:../bin/irssi: rld: Fatal Error: this executable has unresolvable symbols
editnote:
Pulled the source, installed glib to satisfy prereqs, and am now kicking off a build. Will report in. Mind you if anything goes wrong I'm pretty much screwed since I never really got past chapter 1 of K&R :P
:Indigo2IMP: :O2: :Fuel: Image 8/E Image 8/M (1973) Image 8/M (1975)
zmttoxics
Unread postby zmttoxics » Wed Sep 30, 2009 10:58 am
theodric wrote:editnote:
K&R is a little overrated these days. I learned C in college and K&R was definitely the standard, and I bought the book, but I never read it. The only book I read was a C pocket reference book published by Que in the 80s. Any time I got stuck, I just pulled out the pocket book. I still carry it with me everywhere. :)
Stuff.
uridium
Unread postby uridium » Fri Oct 02, 2009 5:50 am
Hi Journeyman, looks like the only dependencies it's linked against is:
jazz:/opt/irssi-0.8.14[4075]%find . -print | xargs file | grep MIPS | cut -f1 -d\: | xargs ldd
        libperl.so  =>   /usr/nekoware/lib/perl5/5.8.8/irix-n32/CORE/libperl.so
        libgmodule-2.0.so.1  =>  /usr/nekoware/lib/libgmodule-2.0.so.1
        libglib-2.0.so.1  =>     /usr/nekoware/lib/libglib-2.0.so.1
        libintl.so.4  =>         /usr/nekoware/lib/libintl.so.4
        libiconv.so.3  =>        /usr/nekoware/lib/libiconv.so.3
        libssl.so.0.9.8  =>      /usr/nekoware/lib/libssl.so.0.9.8
        libcrypto.so.0.9.8  =>   /usr/nekoware/lib/libcrypto.so.0.9.8
        libcurses.so  =>         /usr/lib32/libcurses.so
jazz:/opt/irssi-0.8.14[4076]%
So, quickly guessing from that the dep's would be perl 5.8.x, libgcrypt, ssl, iconv and libintl, gmodule/glib (annoyingly).
You shouldn't need any LD_LIBRARY32_PATH set. I certainly don't. I just set a path to /opt/bin:/usr/nekoware/bin and have a link
in /opt/bin to /opt/irssi-0.8.14/bin/irssi there. Tell me how that goes. :D Happy mircNETting.
Al Boyanich
uridium
Unread postby uridium » Fri Oct 02, 2009 5:52 am
zmttoxics, K&R I always found dry but not bad. The one I get all misty-eyed over is by David Spueler or some such. I got it in TAFE/College around 1993 as my text for Programming Concepts 105. Geeze that was a good book for the era when faced with a Unisys-5000/5085 for the first time :)
Al Boyanich
theodric
Unread postby theodric » Fri Oct 02, 2009 6:27 am
Uber-fail. No idea what's going on here, but I can't use this build.
uridium
Unread postby uridium » Fri Oct 02, 2009 8:00 am
theodric: Hi, looks like your perl 5.8.{8.9} dist is broken or an rqsall bombed. Hmm. Most of those symbols are in nekoware's libperl.so if you run elfdump -cC libperl.so | pg<return> you should see that there's symbols for PL_curpad, PL_sv_yes, PL_op ... are there. Perhaps one of your perl deps is missing? Good place to start :)
Al Boyanich
theodric
Unread postby theodric » Sat Oct 03, 2009 12:01 pm
uridium wrote:theodric: Hi, looks like your perl 5.8.{8.9} dist is broken or an rqsall bombed. Hmm. Most of those symbols are in nekoware's libperl.so if you run elfdump -cC libperl.so | pg<return> you should see that there's symbols for PL_curpad, PL_sv_yes, PL_op ... are there. Perhaps one of your perl deps is missing? Good place to start :)
Thanks for the pointer. I did update to the Perl build sitting in /beta but it didn't seem to make a load of difference. I'm on the wrong side of the (relatively small) country today but I'll be back nearer my machines tomorrow and will have another poke at this.
samus
Unread postby samus » Tue Dec 15, 2009 9:05 pm
thanks it work fine on my octane.. great for using bitlbee
uridium
Unread postby uridium » Tue Dec 15, 2009 9:40 pm
Your welcome. Is bitlbee working under irix these days is it? Hmm, that'd be useful and worth looking into. :)
Al Boyanich
uridium
irssi 0.8.15 n32
Unread postby uridium » Thu Apr 08, 2010 5:07 pm
Huzzah! Alexander Færøy hath blessed the internets with a new release of irssi, v0.8.15! \e/
It also builds on the blessed IRIX.
Get some:
http://deviate.fi/~uridium/irssi-0.8.15 ... 32.tar.bz2
http://deviate.fi/~uridium/irssi-0.8.15 ... ee.tar.bz2
Build env; Usual suspects ..
IP32 R5k @180Mhz
RAM: 128mb
OS: 6.5.29f
Nekoware: -CURRENT as @8-APR-2010
format: mips4, n32
Usual deal, sits in /opt/irssi-0.8.15 so as not to clutter up nekoware. Uses nekoware libs and other
crimes though.
Build time was faster, shade under 2hrs. Might've been quicker if the clown on ip:202.143.133.69 was
n't trying to log into my box as "root" 4x a second and brute force my ssh passwd and flog all my cy
cles! :evil: O.o! Also have a HP-UX version available for hppa1.1 in SOM format, for those that don't think
an IRIX /CTCP version informations is 'cool' enough. Give me a bell if it works or your system expl
odes.
Al Boyanich
