Xchat 2
Shtoink
Xchat 2
Unread postby Shtoink » Sun Mar 02, 2003 10:34 am
Is it possible soemone could compile this and make a tardist out of it?
http://xchat.org/
I would appriciate it very greatly, I imagine that a soe other people might, too. :D
Re: Xchat 2
Unread postby nekonoko » Sun Mar 02, 2003 5:03 pm
You'd have to compile/package a lot of Gnome2 support as well ... is it really that much different than the version on SGI Freeware (1.8.10)?
Shtoink
Unread postby Shtoink » Sun Mar 02, 2003 7:57 pm
Maybe not...
I got all excited to see a new stable version released, but i dug through the change log and didn't see anything in particular that needed it to happen. I supposes that there isn't any good reason other than it might be nice.
lisp
Unread postby lisp » Mon Mar 03, 2003 12:35 am
Are you sure? I compiled up xchat 2, and all the libraries I needed were installed from the latest freeware.
lisa
Unread postby nekonoko » Mon Mar 03, 2003 1:44 am
lisp wrote:Are you sure? I compiled up xchat 2, and all the libraries I needed were installed from the latest freeware.
checking for GLIB - version >= 2.0.3... no
configure: error: "Cannot find glib"
Latest GLIB on SGI Freeware is 1.2.10. It will most likely complain about GTK as well, but configure doesn't make it past GLIB :)
lisp
Unread postby lisp » Mon Mar 03, 2003 3:37 am
glib and glib2 are packaged seperately, IIRC.
lisa
Unread postby nekonoko » Mon Mar 03, 2003 10:46 am
lisp wrote:glib and glib2 are packaged seperately, IIRC.
Ah, I missed that one ... thanks :)
semi-fly
Unread postby semi-fly » Wed Mar 05, 2003 8:57 am
Glib2, glib3, glib-eleven-teen; FSF and OS just own me.
waldo
Unread postby waldo » Wed Mar 05, 2003 11:10 pm
the one major difference i noticed between 1.8 and 2.0 is that they finally group tabs by server. makes it worth the upgrade with that alone imo
Unread postby nekonoko » Sat Mar 08, 2003 4:56 am
I've fought with it a bit ... the configure script doesn't seem to want to see glib-2.0 even though it's installed. Setting CFLAGS='-I/usr/freeware/include/glib-2.0' works for the headers but it craps out trying to link the test program (unresolved symbols). Lots of fun.
vegac
Unread postby vegac » Sat Mar 08, 2003 7:26 am
You can just tell it to skip the tests and "trust you" that they're there...
Unread postby nekonoko » Sat Mar 08, 2003 7:30 am
vegac wrote:You can just tell it to skip the tests and "trust you" that they're there...
Tried that ... it still dies at the glib check even after:
configure --disable-glibtest
The problem is that 'configure' still attempts to check the version of glib on the system, and compiles a small test program to do that.
vegac
Unread postby vegac » Sat Mar 08, 2003 8:03 am
That's nice of it to still do the test after you tell it not you..
It only has your best interest in mind :P
Unread postby nekonoko » Sat Mar 08, 2003 8:04 am
vegac wrote:That's nice of it to still do the test after you tell it not you..
Isn't it great though? :)
Shtoink
Unread postby Shtoink » Sat Mar 08, 2003 8:47 am
nekonoko wrote:Isn't it great though? :)
Doesn't it give warm fuzzies inside...?
:roll:
