Network installation from a Linux server
Unread postby jan-jaap » Fri May 26, 2006 8:05 am
I used to have do my IRIX installations over the network using a Linux server. Everyting was good and nice, until I upgraded the server from Debian "woody" to "sarge". Ever since, I was getting
Failed reading remote directory: (no command)
as soon as you would enter a "from:" line in the miniroot "inst"
I finally found the program that was causing this. You won't believe it. It was /bin/ls :evil:
They managed to @#$% up the 'ls' command !!!
I replaced it with 'ls' from "Woody" and it's installing again. All the usual hacks as documented all over the net still apply.
pipeline
Re: Network installation from a Linux server
Unread postby pipeline » Fri May 26, 2006 8:45 am
jan-jaap wrote:I used to have do my IRIX installations over the network using a Linux server. Everyting was good and nice, until I upgraded the server from Debian "woody" to "sarge". Ever since, I was getting
Holy shit. I'd been wondering about this one for a loooong time. I had been attributing it to brain damage in rsh.
Glad to hear there's a fix!
Ashkente
Unread postby Ashkente » Thu Oct 12, 2006 3:24 pm
If you're still around, would you mind posting what version of ls you are using? I think I'm encountering the same problem, and have somewhat confirmed it with tcpdump.
Thanks!
gcb
Unread postby gcb » Thu Oct 12, 2006 4:19 pm
First time i tried that (had no scsi cdrom) i wasted lots of time tring to please the bootp protocol for the eprom... managed to find good hints here, don't know why i gave up. i think i managed to boot the thing in the end...
Zerolapse
Unread postby Zerolapse » Wed Oct 25, 2006 12:38 pm
Yeah, I was beating myself over the head on that one for awhile too...I just yanked an older version of ls from another box and wrote a small script to switch some symlinks to it around (so as not to potentially break debian scripts), along with the port ranges, etc needed to boot an SGI in Linux.
-Jesse
Unread postby jan-jaap » Thu Oct 26, 2006 2:35 am
Ashkente wrote:If you're still around, would you mind posting what version of ls you are using? I think I'm encountering the same problem, and have somewhat confirmed it with tcpdump.
Thanks!
Sorry, I overlooked this thread. Currently, I have things configured like this:
    Fileserver runs Debian GNU/Linux "Sarge" (with selected backports)
    Server has several "vservers" running, a bit like Solaris zones and FreeBSD jails.
    One of these vservers acts as my install server. That way I isolate the ugly r* stuff (rexec, rcp etc) into a readonly sandbox where it's mostly harmless. This vserver runs "sarge" as well, but /bin/ls has been replaced by the one from Debian 'woody' (fileutils-4.1 package)
The install server sandbox is minimalist enough that I can just replace the /bin/ls, and make /bin/ksh the default shell without crippling the whole server in one way or another.
blue
Unread postby blue » Tue Feb 06, 2007 12:38 pm
I know i'm digging up an ancient thread, but, in order to save anyone else the hours of trouble i had..
I'm using Ubuntu/sparc as my install server.
No matter what I tried, i couldn't get any other user than root to work for rsh, so i've added three lines to the bottom of /etc/securetty to allow root rsh logins.
rlogin
rsh
rexec
/bin/ksh no longer works.. I needed to install pgksh and symlink that to /bin/sh instead.
http://archive.debian.org/debian-archiv ... fileutils/ has the deb files for fileutils-4.1.. download the correct one for your architecture, for example sparc, into an emtpy directory, and dpkg --extract fileutils_4.1-10_sparc.deb. the ls you need will be in the bin/ directory. Be sure you rename the original /bin/ls to something else like ls.original before you copy the new one to /bin as the version in fileutils-4.1 is pretty ugly.[/i]
Alver
Unread postby Alver » Tue Feb 06, 2007 11:23 pm
:shock: You gotta be kidding me. I gave up on it after weeks of sweating & cursing, and just got me a second SGI instead :lol: nice to see someone's got it working after all!
while (!asleep()) sheep++;
porter
Unread postby porter » Wed Feb 07, 2007 3:26 am
NetBSD 3.0 just worked, and I'm wondering what all the fuss is about. :)
