XLV / XVM requirements
shrek
Unread postby shrek » Tue Jul 29, 2003 9:37 am
Hi,
I just received two extra disks for my Origin and wanted to start experimenting with a RAID0 stripe.
However I don't know where the software resides.
I fired up the software manager and opened my 6.5.20m directory. After I selected XVM it tells me it has an unresolved dependencie eoe.sw.xlm however I don't know wat CD to use to resolve this dependency.
Pointers on what media I need to resolve XLV dependency (eoe.sw.xlv) are also welcome.
Re: XLV / XVM requirements
Unread postby nekonoko » Tue Jul 29, 2003 9:49 am
shrek wrote:Hi,
The clue is in the package name:
eoe.sw.xlv
eoe.* is the "IRIX Execution Environment, 6.5.XX" package. Anything listed after the root package (eoe.xxx.xxx) is just a subsystem of that same package. To install subsystems, expand the IRIX Execution Environment, 6.5.XX parent and select the desired subsystem.
Base eoe.* lives on Foundation 1. Your 6.5.20m overlay will also be required.
shrek
Unread postby shrek » Tue Jul 29, 2003 10:13 am
Thank you Neko, I must have overlooked it!
max_impact
Unread postby max_impact » Tue Jul 29, 2003 9:29 pm
Also, if you want to use the XVM gui (useless IMHO), you need to be on the feature stream IIRC.
Return to “SGI: Discussion”
