DNS problems.
semi-fly
DNS problems.
Unread postby semi-fly » Wed Jul 23, 2003 7:55 am
I recently upgraded to Xbow 1.3 and I'm having problems resolving DNS. I can ping any system on the network, mount nfs shares, ssh into the fileserver, but DNS does not seem to be working. I rember a thred about clearing DNS cache or resetting DNS, but I can't seem to locate it...
Re: DNS problems.
Unread postby nekonoko » Wed Jul 23, 2003 8:52 am
semi-fly wrote:I recently upgraded to Xbow 1.3 and I'm having problems resolving DNS. I can ping any system on the network, mount nfs shares, ssh into the fileserver, but DNS does not seem to be working. I rember a thred about clearing DNS cache or resetting DNS, but I can't seem to locate it...
nsadmin restart
Hakimoto
Unread postby Hakimoto » Wed Jul 23, 2003 11:08 am
Speaking of xbows.... can one obtain these ONLY with a chassis or as seperate entities? The whole thing is that I haven´t yet completely dis and reassembled my Octane as I usually do with all my gear... gotta get down to that.
grace, elegance and style.
semi-fly
Re: DNS problems.
Unread postby semi-fly » Wed Jul 23, 2003 4:25 pm
nekonoko wrote:nsadmin restart
that's the command I was looking for, thx nekonoko..
orbital
resolvers...
Unread postby orbital » Fri Jul 25, 2003 12:26 pm
Just a quicky I found out after I set-up bind9 on a linux box; all boxes I tried could use the nameserver except any of my IRIX boxen. The reason, reverse mapping. Once you set-up the reverse mappings the IRIX boxen started using the resolver.
My lazy set-up of a nameserver, but a gotacha anyway.
adi
Host Resolution Order
Unread postby adi » Sun Jul 27, 2003 12:48 am
Hey,
Im having a similar problem. I did a fresh install of Irix about a week ago, and I cannot change the host resolution order from NIS, DNS, Files. Everytime I change it in the Network Setup Dialog, I reboot and its back to the original order. Its really annoying as my computer currently takes 5 minutes to boot up, much longer than my Indigo2!
Do you think the nsadmin restart command would help neko?
Gareth
semi-fly
Unread postby semi-fly » Sun Jul 27, 2003 4:37 am
MIght be a good Idea to run the command. Also check you init files, might need to diabled some undeeded services.
Return to “SGI: Discussion”
