IRIX gamma setting
semi-fly
IRIX gamma setting
Unread postby semi-fly » Thu Jun 26, 2003 11:11 am
Whats the lowest setting you can have for gamma under irix? 1.0, or can you run it lower then that?
Axxe
Unread postby Axxe » Fri Jun 27, 2003 4:19 pm
I think .1 is the lowest.
I never tried it though.
I would be staring at a black screen.
Another question would be,
what gamma setting to use?
Does one use the default of 1.7 or set it to 1.0?
1.0 is used for professional video/film work.
Macs use 1.8 for default.
Insert witty signature here.
Unread postby nekonoko » Fri Jun 27, 2003 4:26 pm
I use 1.0 on my TFTs; colors look great at that setting. A tube based monitor should probably be set a little higher though.
semi-fly
Unread postby semi-fly » Fri Jun 27, 2003 6:50 pm
nekonoko wrote:I use 1.0 on my TFTs; colors look great at that setting. A tube based monitor should probably be set a little higher though.
1.0 here as well.
Hakimoto
Preferences...
Unread postby Hakimoto » Sat Jun 28, 2003 1:57 am
1.4 here, on most systems that support it. But I have a skewed sense of colour according to my work colleagues.
grace, elegance and style.
semi-fly
Unread postby semi-fly » Sat Jun 28, 2003 5:30 pm
I just set it gamma to 0.8, helps just a little with colors on my TFT.
Return to “SGI: Discussion”
