going keyboardless
SparcV
going keyboardless
Unread postby SparcV » Tue Jun 17, 2003 3:00 pm
is there a way to make it so my sgi's can boot without a keyboard attached. When I do it now they complain about the keyboard not being attached. I know there's an env setting in the prom for keyboard input but I dont know what I could put in. I would like to do this with my Indigo and my O2.
Re: going keyboardless
Unread postby nekonoko » Tue Jun 17, 2003 3:02 pm
SparcV
Unread postby SparcV » Tue Jun 17, 2003 3:19 pm
Thats almost what I want to do. I want to have a monitor attached to the machine. I just dont want a keyboard/mouse attached. I want to use the machines to drive a second monitor and use x2x to control it from my Octane.
Unread postby nekonoko » Tue Jun 17, 2003 3:32 pm
Try it and see what happens; that's pretty much the only option. According to the PROM monitor chapter:
nogfxkbd - Specifies that the keyboard is not required to be connected if set to 1.
http://techpubs.sgi.com/library/tpl/cgi ... /ch09.html
Syonyk
Unread postby Syonyk » Sat Jun 21, 2003 12:14 am
I did exactly that (x2x), and the nogfxkbd is the setting to set.
-=Russ=-
Return to “SGI: Discussion”
