Needed Viewsonic Vx2450wm config file for Irix 6.5.30 on Octane with V10
A2666
Unread postby A2666 » Sun Nov 06, 2016 11:50 am
Does anybody have config file I could use for vx2450wm Viewsonic monitor.
I have Octane 2 with V10
Otherwise I am getting only 1280x1024 resolution.
Thanks
2x Octane 2 | 1x Mac Pro (Xeon) | 3x Mac Pro G5 | 4x Thinkpad Laptops | 1x Custom Hackintosh | 1x Amiga 600 | 1x Amiga 2000 (Scsi, 50Mhz Acc, 73Gb HDD, Cybervision 64/3D | Commodore Plus4 | Commodore 64, Atari 1040 STE 12Mb, Panther graphic card, ide etc. | Atari 1040 STF stock | N64 | Sega Dreamcast | Wii | PS3 | Sega Genesis | Nintendo Gamecube
toasty
Re: Needed Viewsonic Vx2450wm config file for Irix 6.5.30 on Octane with V10
Unread postby toasty » Sun Nov 06, 2016 12:52 pm
I have a dell monitor with the same resolution and was able to make a VFO file (see attached). It may or may not work with your monitor but give it a shot! I'm running 1920x1080 @ 60 on my V10 just fine but you need to drop the frame buffer depth from 16 to 8.
If my VFO file doesn't work, install vfc from one of the IRIX overlays. Then run this command:
/usr/sbin/vfc -p "-DACTIVE_LINES=1080" -p "-DACTIVE_PIXELS=1920" -p "-DFPS=60" -c chip=VPro_Chip.def,board=VPro_Board.def -o 1920x1080_60p.vfo /usr/gfx/ucode/vfc/vfs/BlockSync.vfs
And put the vfo file in /usr/gfx/ucode/ODSY/vof
1920x1080_60p.vfo
(8.66 KiB) Downloaded 19 times
Past: :Fuel: :Octane2: :O2: :O2: :O2: :Indy: Present: MacBook
A2666
Unread postby A2666 » Sun Nov 06, 2016 1:41 pm
Awesome. I will try it.
Thank You
Return to “SGI: Discussion”
