O2 ct scanner keyboard problem
tportales
Unread postby tportales » Mon Aug 24, 2015 5:30 pm
hello thank you for your help in advance, my ct scanner uses an "hybrid" keyboard(see attached), the right side of the keyboard (left, right, up, down ,insert, numbers +- etc) stop working , I change the keyboard the same result, do i need to reconfig the keyboard?
regards
Jack Luminous
Re: O2 ct scanner keyboard problem
Unread postby Jack Luminous » Tue Aug 25, 2015 2:32 am
I had the same kind of problem with a wacom tablet. Stopped working one day. Bought a second one. Didn't work either. What was needed was just a reinstall of the driver. it's worth trying anyway. :?
tportales
Unread postby tportales » Tue Aug 25, 2015 8:14 am
Jack thank you for your reply, the problem is the mainboard , i switched it and the keyboard works, i cannot get rid of the mainboard what can i do to solve it?
regards
Unread postby recondas » Tue Aug 25, 2015 4:09 pm
tportales wrote:the problem is the mainboard , i switched it and the keyboard works, i cannot get rid of the mainboard what can i do to solve it?
What is the part number of the system/main board that works with your keyboard? Per chance are your CT Scanner and/or the specialized keyboard connected to one of the O2's serial ports?
The O2 system board came in at least two distinct variants, 030-1227-00x and 030-1327-00x. There have been a number of discussions here that seem to suggest the 030-1327-00x variant is required in O2s used with certain medical imaging equipment, though none of the discussions I found offer definitive proof as to what what differences were present that necessitated the use of the 030-1327-00x.
Here are a couple of the discussions I mentioned; there are others but none seem to offer a better explanation (the second link includes posts by "mapesdhs", an SGI reseller who may be able to offer you additional insight in to your keyboard/system board issue):
viewtopic.php?f=3&t=16727286&p=7355919&#p7355919
viewtopic.php?f=3&t=16726674&p=7350785&#p7350785
BTW, on the odd chance you switched system boards to add a faster processor, you may be able to install the faster processor complex onto the CT scanner friendly system board.
tportales
Unread postby tportales » Wed Aug 26, 2015 10:58 am
Thank you so much for your help the part number is 030-1327-001 and the keyboard is connected to the keyboard port,
thks
Return to “SGI: Discussion”
