gcc default
s0ke
gcc default
Unread postby s0ke » Mon Feb 24, 2003 5:37 pm
How do I set up gcc to be my default compiler, instead of cc (since I am unfortunate and do not have a lics).
What I mean is, instead of typing cc at the command prompt, I want to be able to just type gcc, or use it like vfc -i "cc -E"
vegac
Unread postby vegac » Mon Feb 24, 2003 6:03 pm
First, make sure that /usr/freeware/bin is in your path.
Second, make things with gmake instead of make
Third, you'll most likely have to set some variables, such as
CC=gcc CXX=g++ CFLAGS=-O2 CXXFLAGS=-O2
Then, just make as normal and anything made to compile with GCC should (of course, you may have to ALSO do -I/usr/freeware/include and -L/usr/freeware/lib)
Re: gcc default
Unread postby nekonoko » Mon Feb 24, 2003 8:44 pm
One of the easiest ways to set up your SGI Freeware paths is to just use
/usr/freeware/bin/fixpath ... everything you need will be set up automatically.
s0ke
Unread postby s0ke » Tue Feb 25, 2003 10:17 am
I don't seem to have that command in my freeware directory.
When I run /usr/freeware/bin/fixpath it just says command not found.
Unread postby nekonoko » Tue Feb 25, 2003 10:26 am
toaster wrote:I don't seem to have that command in my freeware directory.
It's part of fw_common; first package in http://freeware.sgi.com/cd-4/dist/
I'll post just the "fixpath" script when I get home from work ... I can't reach my network from work due to the firewall here.
Unread postby nekonoko » Tue Feb 25, 2003 12:28 pm
s0ke
Unread postby s0ke » Tue Feb 25, 2003 1:14 pm
I was able to install it from an old freeware cd and run it, thanks
Return to “SGI: Discussion”
