It is currently Fri Sep 03, 2010 2:18 am
Post new topic Reply to topic  [ 19 posts ]  Go to page 1, 2  Next
 Post subject: Good use for an old Indy: MPD (Music Player Daemon) box
PostPosted: Thu Nov 16, 2006 9:56 pm
I've been going through the giant stack of Indys that I have, selling some on eBay, parting out/testing things from the bad ones, etc.
Having singlehandedly saturated the eBay Indy market for a while, I decided to try something else with one of the ones I had laying around.
I made Music Player Daemon box out of it! :D I may even contribute a tardist to the Nekoware archives here in a few weeks.
It took a bit to get everything sorted out with library locations & some of the other libraries I needed for everything (id3tag was the only one I had to custom compile), but I got it running in an evening. It's mounted my NFS music share, and is happily churning away quietly on top of my stereo.
I didn't realize this until after it was in place, but the volume buttons work! It's the best-suited of the SGIs to stereo-top use - very low power, thin, reasonably light, and volume buttons!
On a R5k 180mhz, it's not even taxing it - ~10% CPU utilization playing back normal MP3s/OGGs. Not really using much memory either, for that matter, and I know I have some services running that I could shut down.
Quote:
CPU: 87.8% idle, 9.3% usr, 2.4% ker, 0.5% wait, 0.0% xbrk, 0.0% intr
Memory: 192M max, 177M avail, 124M free, 128M swap, 128M free swap
So, yea. If anyone wants more info on compiling MPD for IRIX, let me know. And, as I said, I may get around to putting together a few more tardists so it's included in the Nekoware archive.
The other observation I have is that... a blue Indy looks out of place in an audio rack. I'm thinking of using one of the skins that's beat to death & painting it, either gloss black, metal fleck grey, or something steampunk (sort of a rusted iron look).
Questions? Comments?
-=Russ=-
 Post subject: Re: Good use for an old Indy: MPD (Music Player Daemon) box
PostPosted: Thu Nov 16, 2006 10:24 pm
That's very cool. Umm, btw there's an mpd tardist in /beta at the moment that joerg just built. Care to compare performance for us ?
 Post subject:
PostPosted: Thu Nov 16, 2006 10:28 pm
Oh, I didn't look in the /beta section - I just pulled the current section.
I shall take a look at it!
-=Russ=-
 Post subject:
PostPosted: Thu Nov 16, 2006 10:59 pm
foetz used to do that to me all the time - I'd ask "how about blank-blank ?" and he'd say "in my directory or "in beta." Finally I learned to look more carefully :)
Good to have a test of the mpd concept tho and nice to have more people compiling apps. Now, how about a look at Lilypond ?
PostPosted: Fri Dec 11, 2009 8:22 pm
Sorry to dredge up an ancient post.
I have an Indy running Irix 6.5 which I am also planning on using as headless mpd box (using digital audio out to my amp).
I've installed the neko_mpd-0.1.2.tardist and (as far as I can tell) all dependencies but there seems to be a problem with the linked libraries:
Code:
indy 20# mpd
21163:mpd: rld: Fatal Error: Cannot Successfully map soname 'libFLAC.so.5' version 'sgi5.2' under any of the filenames /usr/nekoware/lib/libFLAC.so.5:/usr/lib32/libFLAC.so.5:/usr/lib32/internal/libFLAC.so.5:/lib32/libFLAC.so.5:/opt/lib32/libFLAC.so.5:/usr/nekoware/lib
/libFLAC.so.5.5:/usr/lib32/libFLAC.so.5.5:/usr/lib32/internal/libFLAC.so.5.5:/lib32/libFLAC.so.5.5:/opt/lib32/libFLAC.so.5.5:
I've turned up this thread http://forums.nekochan.net/viewtopic.php?f=7&t=16722067&p=7310365&hilit=libFLAC.so.5#p7310365 which mentions the problem but I can't see a solution.
I'm very new to Irix and any pointers would be most appreciated!
(I have considered resorting to a Debian install just to simplify matters, but would prefer to stick with Irix if I can).
:Indy: :Indy: :Indy: :O2: :O2: :1600SW: :1600SW:
 Profile E-mail
PostPosted: Sat Dec 12, 2009 5:05 pm
You could try XMMS2. It's got the same client/server model and the great thing about it is that it plays a lot of formats compared to MPD, which seems to be at a development standstill. I'd never go back to MPD.
 Profile E-mail
PostPosted: Sat Dec 12, 2009 8:58 pm
bviking wrote:
Code:
indy 20# mpd
Do a "Find" for libFLAC ? If it's not there, then you are missing a library. If it is, then this might be one of those cases for LD_LIBRARYN32_PATH. There's a current thread about that.
Unless you are particularly attached to MPD, ritchan's suggestion is probably a good one.
PostPosted: Sun Dec 13, 2009 12:49 am
Thanks for the suggestions.
I have libFLAC.so.9 in /usr/nekoware/lib.
It seems that libFLAC.so.5 is expected.
ldd gives this:
Code:
indy 4# ldd /usr/nekoware/bin/mpd
        libsocket.so  =>         /usr/lib32/libsocket.so
        libnsl.so  =>    /usr/lib32/libnsl.so
        libao.so.3  =>   /usr/nekoware/lib/libao.so.3
        libdl.so  =>     /usr/lib32/libdl.so
        libshout.so.4  =>        /usr/nekoware/lib/libshout.so.4
        libtheora.so.1  =>       /usr/nekoware/lib/libtheora.so.1
        libspeex.so.2  =>        /usr/nekoware/lib/libspeex.so.2
        libiconv.so.3  =>        /usr/nekoware/lib/libiconv.so.3
        libmad.so.1  =>  /usr/nekoware/lib/libmad.so.1
        libfaad.so.1  =>         /usr/nekoware/lib/libfaad.so.1
        libvorbisfile.so.4  =>   /usr/nekoware/lib/libvorbisfile.so.4
        libvorbisenc.so.3  =>    /usr/nekoware/lib/libvorbisenc.so.3
        libvorbis.so.1  =>       /usr/nekoware/lib/libvorbis.so.1
        libogg.so.1  =>  /usr/nekoware/lib/libogg.so.1
22575: 21:02:28 /usr/nekoware/bin/mpd: rld: Fatal Error exit/longjmp: Cannot Successfully map soname 'libFLAC.so.5' version 'sgi5.2' under any of the filenames /usr/nekoware/lib/libFLAC.so.5:/usr/lib32/libFLAC.so.5:/usr/lib32/internal/libFLAC.so.5:/lib32/libFLAC.so.5:/opt/lib32/libFLAC.so.5:/usr/nekoware/lib/libFLAC.so.5.5:/usr/lib32/libFLAC.so.5.5:/usr/lib32/internal/libFLAC.so.5.5:/lib32/libFLAC.so.5.5:/opt/lib32/libFLAC.so.5.5:
22575:/usr/nekoware/bin/mpd: rld: Fatal Error: Cannot Successfully map soname 'libFLAC.so.5' version 'sgi5.2' under any of the filenames /usr/nekoware/lib/libFLAC.so.5:/usr/lib32/libFLAC.so.5:/usr/lib32/internal/libFLAC.so.5:/lib32/libFLAC.so.5:/opt/lib32/libFLAC.so.5:/usr/nekoware/lib/libFLAC.so.5.5:/usr/lib32/libFLAC.so.5.5:/usr/lib32/internal/libFLAC.so.5.5:/lib32/libFLAC.so.5.5:/opt/lib32/libFLAC.so.5.5:
I'll look into xmms - although from a quick look nekoware doesn't seem to have a tardist of xmms2?
 Profile E-mail
PostPosted: Sun Dec 13, 2009 12:55 am
Quick and dirty ? make a link, rename it with the wrong number and try it.
PostPosted: Sun Dec 13, 2009 3:47 am
Hmm. Thanks for the suggestion, but unfortunately no cigar - I still get the same output.
 Profile E-mail
PostPosted: Sun Dec 13, 2009 4:21 am
Did a couple things, maybe can save you a few moments :
Searched for libFLAC.so.5, I don't have it either. Judging by the original post, perhaps the op compiled it with his mpd.
Did a quick download of xmms2,
Code:
fewel 17% ./waf configure --prefix=/usr/testware -p
Traceback (most recent call last):
  File "./waf", line 11, in <module>
    imp.load_source("waf","waf-light")
  File "waf-light", line 126, in <module>
    import Scripting
  File "/usr/people/me/sata/xmms2/wafadmin/Scripting.py", line 7, in <module>
    import os, sys, shutil, traceback, time
ImportError: No module named time
Piss on them from a great height. Maybe I'll give mpd a shot a little later.
Edit :
Went here, there's been a lot of recent work on MPD
http://mpd.wikia.com/wiki/Music_Player_Daemon_Wiki
grabbed the source for the server, it compiled out of the box.. Yippee. Someone with a brain. Didn't try any of the clients. Xmms2, you may lick my sweaty nutsack.
bviking, do you have a compiler ? There are a ton of options from which you might want to choose. I could email you the server demon but it would be better if you set it up the way you want. Or maybe we could get canavan involved in this ? He's good with all the audio stuff. I'm just a buffoon beating the ground with a stick as far as coding goes.
PostPosted: Sun Dec 13, 2009 4:40 am
Thanks hamei
At least I know it's not just me!
 Profile E-mail
PostPosted: Sun Dec 13, 2009 6:21 am
Over here, it compiles, but without libmad support, i.e. no mp3. Just like with ffmpeg, curl and sqlite, it appears to require pkgconfig support for almost everything, but I don't see anything related to pkgconfig in either the libmad sources or tne nekoware package. It turns out those .pc-files are only part of the debian packages. I've just sent maxk of the mpd project an email about this - if he's not out cycling or flying
The otther problem of course is that the old mpd versions don't compile against the current libflac.
PostPosted: Sun Dec 13, 2009 7:06 am
what an adventure!
I grabbed mpd-0.13.0 to give this a go. I needed to install neko_pkgconfig in order to get the configure script to run but am compiling now.
Will post back once I've had a poke around.
 Profile E-mail
PostPosted: Sun Dec 13, 2009 7:16 am
mmm. seems I posted too soon.
my build fails with the following:
Code:
[snip]
ld32: WARNING 134: weak definition of get_myaddress in /usr/lib32/libnsl.so preempts that weak definition in /usr/lib32/libc.so.
ld32: WARNING 134: weak definition of host2netname in /usr/lib32/libnsl.so preempts that weak definition in /usr/lib32/libc.so.
ld32: WARNING 134: weak definition of netname2host in /usr/lib32/libnsl.so preempts that weak definition in /usr/lib32/libc.so.
ld32: WARNING 85: definition of _netname2host in /usr/lib32/libnsl.so preempts that definition in /usr/lib32/libc.so.
ld32: WARNING 134: weak definition of user2netname in /usr/lib32/libnsl.so preempts that weak definition in /usr/lib32/libc.so.
ld32: WARNING 85: definition of _getnetname in /usr/lib32/libnsl.so preempts that definition in /usr/lib32/libc.so.
ld32: Giving up after printing 50 warnings.  Use -wall to print all warnings.
ld32: ERROR 33: Unresolved text symbol "vorbis_encode_init_vbr" -- 1st referenced by mpd-audioOutput_shout.o.
        Use linker option -v to see when and which objects, archives and dsos are loaded.
ld32: ERROR 33: Unresolved text symbol "vorbis_encode_init" -- 1st referenced by mpd-audioOutput_shout.o.
ld32: ERROR 33: Unresolved text symbol "dirname" -- 1st referenced by mpd-directory.o.
ld32: INFO 152: Output file removed because of error.
collect2: ld returned 2 exit status
*** Error code 1 (bu21)
 Profile E-mail
Users browsing this forum: MSN [Bot] and 1 guest
