unlabeled freeware cds
Unread postby andikas » Thu Feb 20, 2003 5:21 am
I created a set of the sgi freeware cds, downloading the packages
from sgi.com and creating iso-images with mkisofs ( including the parameter for creating cds with rockridge extensions ) and burning everything with cdrecord.
I also specified the parameter for the label of the cds. However irix doesn't recognize this label since feeding the cds into swmgr causes the program to ask for insert cd --unlabeled--, whenever a cd has to be inserted, which is quite anoying when installing software from 7 cds :? (overlays + freeware)
Can anyone give me directions on this ?
Unread postby vegac » Thu Feb 20, 2003 6:52 am
I *THINK* that SGI's CDs are actually using EFS, NOT the standard ISO9660...
Though regardless, I don't know why they wouldn't get the CD label right still...
Unread postby orionpi » Thu Feb 20, 2003 9:24 am
I've noticed that all the SGI CD's have a hidden file named .IM that contains a quick volume description, take a look at your IRIX CD's (6.2 and 6.5 have them) and add the description files.
Unread postby directedition » Thu Feb 20, 2003 10:43 am
I took a look at the SGI Freeware CDs I got from Ian Mapleson. They all have a file called README which is opened by the Software Manager whenever a new CD is entered, and there is also an empty file called .distribution on the CD as well.
- Jim
Return to “SGI: Discussion”
Users browsing this forum: Baidu [Spider] and 1 guest
