Rebuilding a SGI Indy. My FIRST SGI!..........
Gray Fox
Unread postby Gray Fox » Sun May 08, 2005 5:33 pm
Im rebuilding a sgi indy that i got this year. This is my FIRST SGI! So I want it to work. Parts I need is.........
SCSI HDD 1-4GB
SGI OS
CPU
Floppy Drive
EXT SCSI CD-ROM
8 32 sticks of ram (256 total)
or
4 32 sticks will do
codemonkey
Unread postby codemonkey » Sun May 08, 2005 5:36 pm
I have a 1.2 GB 50 pin scsi drive you can have for free if you'll pay the shipping. But as your in Canada, it's prob much cheaper getting the parts more locally.
Edit: If your interested in just getting an Indy, it would be much cheaper still to buy the indy whole as a full mchine is worth less than the sum of it's parts.
Even the reverse side has a reverse side - Japanese Proverb
Intel-OUTSIDE
Unread postby Intel-OUTSIDE » Sun May 08, 2005 9:54 pm
get an 18gig harddrive, and forget the floppy.
check this out!
http://www.maestling.com/indy-cdrom/
probably NOT for beginers to case-modding.
MooglyGuy
Unread postby MooglyGuy » Mon May 09, 2005 7:52 am
Also, you can't ask for "SGI OS" - that is, IRIX, please get it right - unless I'm utterly mistaken...
Return to “Hardware Wanted”
