13W3-HD15 adapter
Re: 13W3-HD15 adapter
Unread postby recondas » Wed Feb 20, 2008 1:12 pm
ohw0571 wrote:I need an adapter 13W3(M)-HD15(F).
(I know eBay lists quite a lot of these things, but most of them have opposite gender...
If you've already got one <or can get one easily), you could try a 13W3>HD15 cable with a gender changer on the HD15 end <or use the gender changer with the adapter if you can't find an adapter with a female HD15 end>.
Unread postby Bishop2K » Fri Feb 22, 2008 3:43 am
Yeah, I don't think I've ever seen one with a female 15. Always had to use a gender blender.
If anyone actually has a practical use for a 128P Origin 3800, I'd like to know about it...
Unread postby JacquesT » Sun Feb 24, 2008 4:08 am
If your'e still looking you may be interested in this item on ebay.co.uk.
Iten number: 220205389759
The guy says it was used on an Octane, and it's £5...He says he'll post to UK but am sure he could be convinced to ship to Germany.
Good luck in your search. ;)
:Octane: - 1xR12k 400Mhz, 2GB RAM, V8 graphics, 36GB 15K RPM HDD. Cherokee, XBow and HD fan mod. 6.5.26
:Octane: wip build - Currently 2xR10k 250Mhz, No RAM, SSE graphics, 18GB 15K RPM HDD. Lucent PSU,
Need a SCSI backplane fan shroud please!
Unread postby cybercow » Sun Feb 24, 2008 4:31 am
... Or you can make one by your own in few hours ;) i used 13w3 cable from Sun ...
Unread postby jnolck » Tue Mar 04, 2008 11:43 pm
deepspacecables sells them. I'm sure they'll ship to Germany. Be patient though, they can take a long time to deliver sometimes :(. http://www.deepspacecables.com/models/octane.html. I have the same setup you do, they work like a champ.
Octane 2xr10k, 225mhz, 512mb, 8.3gb harriet
02 r10k, 150mhz, 256MB, 4GB johannah
Ultra10 333MHz US-IIi, 512MB, 20GB alissa
SB2000 2x750Mhz US-III, 2GB, 36GB cheryl
Return to “Hardware Wanted”
