rackmount kit for PowerMacG4
shutitalldown
Unread postby shutitalldown » Fri Mar 02, 2018 9:55 am
let me know by PM!
I am tattooed in reverse, cause if you break rules you don't know where it leads.
But, say, all the venus in furs are so manically depressed and manically dressed.
Re: rackmount kit for PowerMacG4
Unread postby uunix » Fri Mar 02, 2018 11:00 am
Let you know what?
shutitalldown
Unread postby shutitalldown » Fri Mar 02, 2018 11:02 am
do you have one for sale? let me know by PM!
Unread postby ClassicHasClass » Sun Mar 04, 2018 12:06 am
Candidly, if you just want a rackmount G4, it might be easier (and even cheaper) to just find an Xserve.
shutitalldown
Unread postby shutitalldown » Sun Mar 04, 2018 4:46 am
I don't want to buy another machine :D
I am looking for a (second hand) Marathon Computer Rack Mount and slide rails for G3/G4 PowerMac G-Rack!
Shiunbird
Unread postby Shiunbird » Mon Mar 05, 2018 1:04 am
ClassicHasClass wrote:Candidly, if you just want a rackmount G4, it might be easier (and even cheaper) to just find an Xserve.
Given how loud the late G4s are, no amount of acoustic preparation would be able to keep your home safe of a bunch of Xserve G4s.
shutitalldown
Unread postby shutitalldown » Mon Mar 05, 2018 2:57 am
The G4 MDD takes 12U in the rack, that is a lot of space!!, but I need four PCI-X/3.3V-5V slots long-size and Xserve/G4's && Xserve/G4-Slot-Load's both come with the PCI slots, while Xserve/G4-Cluster-Node's come with two PCI slots, and they are both of small-size!
No way!
But! for sure I will buy a couple of Xserve G5 (PowerPC IBM 970FX), because they have a true 64bit CPU and come with a couple of PCI-X (3.3V-only?).
spiroyster
Unread postby spiroyster » Mon Mar 05, 2018 2:45 pm
Sorry, can't help but what about a shelf? Surely that would be adaquate...
I can see the attraction if mounting horizontally... but vertically? Unless it needs to be installed on a fault line or something o.0
If you deskin it, you could probably get 3 in there too.
CLICK HERE to find out what click bait is. You will not believe what you discover.
#NaN singles in your area are already making gazzilions by using this trick.
Cambridge Analytica approved!!
shutitalldown
Unread postby shutitalldown » Mon Mar 05, 2018 3:29 pm
spiroyster wrote:vertically?
on the same plane, next to the MDD, I would put a vertical disk-array, that takes exactly 12U.
It perfectly fits :D
Shiunbird
Unread postby Shiunbird » Tue Mar 06, 2018 12:21 am
That's a very nice rack! NASA property, hmm... whoever owns this nowadays is a happy dude (or dudette).
I thought the XServer RAID was 4U.
spiroyster
Unread postby spiroyster » Tue Mar 06, 2018 4:09 am
Ah ok... those maraton 'braces' seem remarkably overpriced (if you could find one)... certainly for myself I think would explore other avenues to prop up the mac if putting in a 'static' rack if it's always going to be vertical .... seems like you have a plan, good luck!
Unread postby ClassicHasClass » Tue Mar 06, 2018 7:38 am
You could rack mount an Apple Network Server, too, but I'm here to say from personal experience it wasn't a good idea. :P
shutitalldown
Unread postby shutitalldown » Tue Mar 06, 2018 10:46 am
ClassicHasClass wrote:it wasn't a good idea
why?
ScutBoy
Unread postby ScutBoy » Tue Mar 06, 2018 11:16 am
The rackmount kit for a Sun E450 was a flat steel shelf with some dimples for the casters to sit in...
:O2: :Indigo: :Cube: Image
Unread postby ClassicHasClass » Tue Mar 06, 2018 12:05 pm
why?
Because it was almost 15U in a standard rack and it looked stupid. I didn't think to take a picture of it when we tried, though (Apple did actually sell locking plates for it and I have a set somewhere). It was a very similar idea to what ScutBoy described.
Return to “Hardware Wanted”
