WTB: Apple PowerBook G4 Titanium's motherboard, Wanted Dead or Alive
quinn
Unread postby quinn » Sun Nov 12, 2017 1:07 pm
Wanted Dead or Alive.
Only need the Motherboard.
But must be the DVI version.
PM me if you have.
JacquesT
Re: WTB: Apple PowerBook G4 Titanium's motherboard, Wanted Dead or Alive
Unread postby JacquesT » Tue Nov 14, 2017 1:08 am
Pity, I put a maxed out one on the dumpster a few years ago after nobody took up an offer of 99p BIN on ebay :( The lcd had gone when the hinges snapped.
Good luck finding one.
:Octane: - 1xR12k 400Mhz, 1GB RAM, V8 GFX, 18Gb 10K & 36Gb 15K HDD, 6.5.30
:Octane: - 1xR12k 300Mhz, 384Mb RAM, SSE GFX, 18Gb 10K HDD, 6.5.30
:O2: - 180Mhz R5k, 384Mb RAM, 36Gb 15K RPM HDD, A/V Module, 4x CD-ROM, 6.5.30
quinn
Unread postby quinn » Tue Nov 14, 2017 4:03 am
Thanks!
Only interested in a couple of connectors mounted on the motherboard.
Probably they are customized.
smj
Unread postby smj » Tue Nov 14, 2017 10:46 pm
Where are you located? I've got a 400MHz TiBook (Mercury?) around here somewhere that a cheap knock-off power adapter killed...
quinn
Unread postby quinn » Wed Nov 15, 2017 4:03 am
smj wrote:400MHz TiBook
Afraid it must be DVI version: >= 600Mhz version mobos have different connectors installed.
Anyway, once spent hours searching the catalogs of Molex, Hirose, JAE to no avail. It is labelled, but not with a logo: "PCT T2447" on the FPC side, and "PCT T3172" on the PCB side. PCT is Polycyclohexylene Terephthalates, which are used by Samtec among others.
smj
Unread postby smj » Wed Nov 15, 2017 10:22 am
Hmm. I took a quick look last night, but couldn't find the unit. I thought it had a DVI connector, but perhaps I'm confusing it with the other TiBook I have.
Return to “Hardware Wanted”
