Wanted: RM9-64 Raster managers for Onyx2
jebmayers
Unread postby jebmayers » Fri Nov 03, 2017 1:09 pm
Hi all,
Does anyone have 2xRM9-64 Raster Managers for an Onyx2 for sale?
Alternatively 6 RM10s or RM11s ;- although I think that might bankrupt me! ;o)
Cheers
Jeb
msunix
Re: Wanted: RM9-64 Raster managers for Onyx2
Unread postby msunix » Sat Nov 04, 2017 8:00 am
Hi Jeb,
if mopar5150 would sell me two of his RM11's for a reasonable price (hopefully still waiting for answer... :?: ;) ) i could sell you my RM9's... :)
Otherwise there are some on ebay currently, IMO not too expensive...
Michael
:Onyx2: :O200: :Fuel: :Octane2: :Octane: :O2: :Indigo2IMP: :Indigo2: :Indigo2: :Indy: :Indigo: :Indigo: :1600SW:
jebmayers
Unread postby jebmayers » Sat Nov 04, 2017 9:23 am
Hi Michael - yes that sounds like a plan. I was tempted to see what mopar5150 could do also, but to go full RM11 I would have to replace the 4xRM9's I already have.
I assume you can't mix RMs in the same pipe? i am guessing that you could have a IR2E Pipe and an IR3/4 Pipe in the same system though? Anyone know for sure?
Jeb
msunix
Unread postby msunix » Sat Nov 04, 2017 9:46 am
Hi Jeb,
that's exactly true, you can't mix different RM's in the same pipe, but it is possible to mix pipes with different RM's in one system.
Because i only own a deskside ONYX2 i don't have to reflect about such problems, there is only space for one pipe with max. two RM's.
Michael
jebmayers
Unread postby jebmayers » Sat Nov 04, 2017 10:09 am
Thanks for confirming that. It does potentially give me a few more options ;o)
mopar5150
Unread postby mopar5150 » Sun Nov 05, 2017 10:15 am
msunix wrote:Hi Jeb,
Michael
Looks like I am a bit behind on my emails. :D What is a reasonable price for RM-11s these days? The IR4 g-brick I have will likely get parted out since there are no real buyers out there for it.
Thanks,
John
:Tezro: :O3x0: :A350:
msunix
Unread postby msunix » Sun Nov 05, 2017 11:11 am
Hi John,
i think the market for complete pipes would be very small nowadays.
As an example, i'll observe this offer for an RM11 on ebay since a while (it's not sold for months...):
https://www.ebay.com/itm/SGI-RM11-Raster-Manager-for-InfiniteReality4-Graphics-w-1024MB-Texture/272615424666?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
I'll send you a private message...
Michael
Return to “Hardware Wanted”
