Dead Fuel Power Supplies
astouffer
Unread postby astouffer » Sat Oct 21, 2017 3:38 pm
Anyone with a dead fuel power supply laying around? I will take it off your hands. USA only.
kubatyszko
Re: Dead Fuel Power Supplies
Unread postby kubatyszko » Sun Oct 22, 2017 6:15 pm
Are you trying to repair ? have you figured it out ?
astouffer
Unread postby astouffer » Mon Oct 23, 2017 5:47 am
Yeah I just repaired a dead Sparkle power supply.
kubatyszko
Unread postby kubatyszko » Thu Oct 26, 2017 12:14 am
Interesting, would you share some experience from the repair ? Many of us would really like to know more :)
astouffer
Unread postby astouffer » Thu Oct 26, 2017 6:05 am
If you're not comfortable working with electronics I wouldn't attempt this. These supplies are twice the parts density of a normal PC supply. In other words 10 pounds of shit in a 5 pound box.
There are two main boards with numerous daughter boards standing upright. The top output board had many leaky and swelled capacitors. I replaced them all with low ESR or low impedance caps. The height on a few are critical so make sure you match the dimensions otherwise that small fan board won't fit anywhere. There are a lot of smaller caps scattered around which I replaced as well. Don't bother with all the small black ones on the daughter boards. You'll need a good solder rework station for some parts due to the amount of copper on the boards. Forget that 25 watt pencil iron.
I checked a lot of components like MosFETS and diodes with a meter and all appeared well. You will read about 4 ohms to ground on the +5 volt bus. It has load resistors. The +5 standby board sits upright near the edge of the main bottom board. There is a 2 watt 220K resistor that was open on mine. Desoldering the standby board makes it much easier.
Some of the larger parts had a type of cement to keep them from touching other very close parts. I used some electronic grade silicon to secure them again and reassembled everything. Fired it up and was greeted with the l1 prompt. Parts were $20-$25 total.
Return to “Hardware Wanted”
