WTB O2 midplanes, 02+ skins, rm7000 CPU, FPA
karbonKid
Unread postby karbonKid » Mon Sep 11, 2017 4:51 pm
Hi,
I'm after the following bits and bobs for O2s, or full machines, depending on what's available and prices:
- O2 FPA
- 02+ skin
- O2 midplanes (2 required)
- Rm7000 600MHz CPU -- how much should I expect to pay for one of these nowadays?
- Presenter 1280? (I already have the adapter for this)
Re: WTB O2 midplanes, 02+ skins, rm7000 CPU, FPA
Unread postby Raion-Fox » Mon Sep 11, 2017 11:09 pm
I have a midplane I can sell. Do you need me to drill it out of the case?
karbonKid
Unread postby karbonKid » Tue Sep 12, 2017 12:42 am
By midplane I mean the PCB with SCA connectors -- is it riveted in? That complicates things.
Whereabouts are you based?
Intuition
Unread postby Intuition » Tue Sep 12, 2017 8:20 am
Ian might have the o2+ skins available.
Did you check his "Ian's SGI depot" site?
Image O2 - R12K-300
Image O2 - R12K-400 :1600SW: 1600sw
:Octane: R12k 300 :O200: Origin 200
aka Casey Christopher
Unread postby Raion-Fox » Tue Sep 12, 2017 10:23 am
karbonKid wrote:By midplane I mean the PCB with SCA connectors -- is it riveted in? That complicates things.
In Virginia. Yes, the PCB is riveted in on my version
karbonKid
Unread postby karbonKid » Tue Sep 12, 2017 10:25 am
Ok, probably not worth shipping the whole chassis or drilling out the rivets. I'm in the UK.
The issue with mine is broken ends on the SCA connectors. Maybe I can 3D print a fix.
Unread postby Raion-Fox » Tue Sep 12, 2017 10:29 am
I mean it's not too hard to drill out the rivets. You can then weld in studs on which you can attach nuts.
karbonKid
Unread postby karbonKid » Tue Sep 12, 2017 10:34 am
Thanks for the offer. Let me check out the state of my boards over the weekend and get back to you.
Return to “Hardware Wanted”
