WTB: Origin 350 for graphics mod
bjornl
Unread postby bjornl » Sun May 14, 2017 9:53 am
Hi,
I'm interested in buying an Origin 350 to put V10 graphics into.
These type of machines must still be in use, because they don't turn up on, for example, eBay. I have only seen parts, not whole machines.
Because of shipping a seller in Europe is preferred, but maybe one "little" O350 is not so expensive to ship overseas.
Unless someone has found out a way to make a graphics mod to an Origin 300 (because I have O300) :-)
Re: WTB: Origin 350 for graphics mod
Unread postby Raion-Fox » Sun May 14, 2017 10:07 am
You can't graphics mod an O300 without hooking it up to a G-brick.
Ask dhjj
japes
Unread postby japes » Sun May 14, 2017 3:40 pm
Possibly a V-Brick with a V12 in it (or presumably any Octane style V-Pro).
Or modified X-Brick maybe? I recall someone was trying that and it didn't provide power, but they piped in the power and it worked?
Finding an Origin 350 will probably be easier. Getting a G-Brick would be nice if you have the space/power.
bjornl
Unread postby bjornl » Mon May 15, 2017 2:14 pm
Thank you guys
I actually have a G-brick in my Onyx2 which I bought a KTOWN2 for and tested with the O300. It was cool, but I didn't
want to swap back and forth so I bought a second Onyx2 :-)
However my O300 is in a short rack and I didn't like the looks of having a skinless G-brick on top of that. It would be much
nicer to have it all inside the short rack. The G-brick will become an Onyx2 again.
Even if a V-brick or X-brick could work, I guess they probably need 48V power supply/power bay and more modifications.
I'll keep my eyes open for an O350. That is probably easiest, even though it may take a while.
mopar5150
Unread postby mopar5150 » Mon May 15, 2017 2:41 pm
I have a few that already have the V10 mod if you are interested. Shipping to Sweden might be too much. I can also sell you just the graphics conversion parts needed. That way you could get the heavy part there. PM sent
:Tezro: :O3x0: :A350:
dhjj
Unread postby dhjj » Tue May 23, 2017 7:37 pm
viewtopic.php?f=4&t=16731749&p=7399280&hilit=v10#p7399280
I listed a v10 graphics here a bit ago. still avail
Return to “Hardware Wanted”
