WTB-Indigo2 Stuff
itsvince725
Re: WTB-Indigo2 Stuff
Unread postby itsvince725 » Wed Mar 22, 2017 1:56 pm
I actually purchased the sleds I need from another Nekochan member and a CD drive off eBay that I'm hoping will work, but I'll keep you in mind if the CD drive isn't good!
:Indigo2: :Indy:
mopar5150
Unread postby mopar5150 » Mon Mar 27, 2017 8:38 pm
itsvince725 wrote:I actually purchased the sleds I need from another Nekochan member and a CD drive off eBay that I'm hoping will work, but I'll keep you in mind if the CD drive isn't good!
If you get the cd sled that is the hard part. If you need a 50 pin CD drive let me know and I will send you one.
:Tezro: :O3x0: :A350:
itsvince725
Unread postby itsvince725 » Mon May 15, 2017 7:52 pm
I figured out what my Indigo2 needs is not a graphics board, but a power supply...what's the part number(s) for teal Indigo2 power supplies? Found some PSUs on eBay but don't know if they're for R4x00 or R10k systems.
:Indigo2: :Indy:
Unread postby Raion-Fox » Mon May 15, 2017 9:53 pm
060-0021-001
R4k and R10k PSUs are the same, its the non-impact graphics you want. So there you go
japes
Unread postby japes » Mon May 15, 2017 10:50 pm
Or you can get the impact ready powersupply and if you ever want to run an impact graphics card you'll be ready (well, you need the riser too I guess). Just make sure you plug the impact/gio power into the terminator on the powersupply if you don't have an impact graphics card installed (regardless of having the riser)
Unread postby dexter1 » Tue May 16, 2017 12:47 am
japes wrote:Or you can get the impact ready powersupply and if you ever want to run an impact graphics card you'll be ready (well, you need the riser too I guess)
For upgrading to Impact systems you need at least a PROM revision "SGI Version 5.3 Rev E IP22 Sep 28, 1995" or "SGI Version 5.3 Rev E IP22 Jan 29, 1996" which correspond to part# 070-1367-011 and -012
Oxygen2
Unread postby Oxygen2 » Tue May 16, 2017 1:13 am
Raion-Fox wrote:Ensure your monitor is sync-on-green compatible.
http://ps-2.kev009.com/sog/
here is the list of compatible monitors
God created the world. The rest made in china.
Image O2 R5K 512Mb RAM 73Gb Barco Chameleon neko
Image O2 R10K 1Gb RAM 73Gb Barco Chameleon AV1 tomcat
Image O2 R5K 256Mb RAM 73Gb kitty
Image Octane2 R10K 2x250Mhz 2Gb 73Gb MX grinch
Building Octane (65%): Case Octane, PSU Cherokee, XBow 1.4, Latest Mobo Octane2, Odyssey VPro V10
itsvince725
Unread postby itsvince725 » Tue May 16, 2017 2:58 pm
Raion-Fox wrote:060-0021-001
http://www.ebay.com/itm/SGI-Silicon-Gra ... 4902.l9144
Does that mean this is an Impact PSU?
:Indigo2: :Indy:
Unread postby dexter1 » Tue May 16, 2017 3:42 pm
itsvince725 wrote:http://www.ebay.com/itm/SGI-Silicon-Graphics-Indigo2-ITT-Power-Systems-PEC4074-6064470-Power-Supply-Used/291817009581?_trksid=p2485497.m4902.l9144
From the ebay listing i infer type 9430814. Jodeman lists in http://www.oocities.org/siliconvalley/h ... upply.html that this is a PSU for R4K/R8K systems with Express GFX.
Also, the blue impact power cable for the riser is not there, so it's evident from the pictures that this is not an Impact PSU.
itsvince725
Unread postby itsvince725 » Tue May 16, 2017 5:18 pm
Ah, I didn't know Impact PSUs had a blue power cable! That helps a lot, thank you.
I might as well get an Impact PSU, unless they're significantly more expensive.
:Indigo2: :Indy:
Unread postby Trippynet » Wed May 17, 2017 1:09 am
They can be more expensive, but it varies. Also because SGI made several different IMPACT-ready PSUs. There's a 36A one and a 48A one, plus several different revisions of them. There's a full list of the different ones on Ian's site in his parts section.
itsvince725
Unread postby itsvince725 » Wed May 17, 2017 10:00 am
http://www.ebay.com/itm/SGI-Silicon-Gra ... Ciid%253A2
That's honestly not a bad price for a proprietary PSU, and I could easily knock a few bucks off by making an offer...
:Indigo2: :Indy:
Unread postby Raion-Fox » Wed May 17, 2017 10:20 am
Not bad at all. Hope it works out for you Vince
itsvince725
Unread postby itsvince725 » Wed May 17, 2017 11:54 am
I might as well add in extra power capacity, even if I don't end up using it. It's hard to have a PSU that's too powerful. :P
:Indigo2: :Indy:
Return to “Hardware Wanted”
