[Found] 180MHz Indy CPU
zafunk
Unread postby zafunk » Sun Dec 18, 2011 6:26 am
Got the 180MHz CPU. Still casually looking for a new mobo though.
Seems to be a hot item at the moment, but if anyone has one to offer, I'm looking. I already have the appropriate PROM Version:
PROM Monitor SGI Version 5.3 Rev B10 R4X00/R5000 IP24 Feb 12, 1996 (BE)
Would also consider a whole system, as my current rig has a problem with the external SCSI bus (anyone local?).
Return to “Hardware Wanted”
