WTB: 013-1673-002 IP25 4x195_2M
mashek
Unread postby mashek » Wed Feb 23, 2011 2:47 pm
I am in need of 3 of these. The part number must be an exact match.
If you have one that has a processor not showing up, offer that also.
Thanks,
Doug
Douglas V. Mashek mailto:doug@mashek.com
Mashek Systems www: http://www.mashek.com
:320: :540: :1600SW: :O2: :O2+: :Indigo: :Octane: :Octane2: :Tezro: :Indigo2: :Indigo2IMP: :Indy: :Fuel: :PI: :O200: :Onyx: :ChallengeXL: :OnyxR: :O2000: :Onyx2: :O2000R: :O2000E: :O2000E: :O2000E: :metarouter: :O2000E: :O2000E: :O2000E: :O2000E: :Onyx2RE: :Onyx2RE: :Onyx2R: :Onyx2RE: :O3000: :O3000: :O3200: :0300: :0300: :0300: :0300:...
dhjj
Re: WTB: 013-1673-002 IP25 4x195_2M
Unread postby dhjj » Thu Feb 24, 2011 6:11 am
you and the rest of the broker world
MisterDNA
Unread postby MisterDNA » Thu Feb 24, 2011 8:11 am
I could barely even give one of those away back in 2005. I think I got an I2 for it.
-- I'm a PeeCee and I can kick your ass. --
Slow PeeCee - i7 940 OC 4.1GHz, 20GB DDR3 OC 1.8GHz, 2x1TB WD RAID0, ATI 5870 1GB, 3008WFP
Dev PeeCee - IBM Intellistation A Pro - Dual Opteron 290 2.8GHz, 8GB ECC DDR, 500GB SATA, 8400GS, 2x1800FP
Slow PeeCee Cluster - 30x Opteron 275, 60.5GB RAM, 2.2TB, 2x1.5TB
Octane 2xR12K-300, 1.5GB, 36GB 10K, 73GB 10K, V8
Indigo2 195MHz, 1GB, 36GB, SI
There are 10 kinds of people in the world:
Those who understand Ternary. Those who don't. Those who could give a shit less.
mapesdhs
Unread postby mapesdhs » Fri Feb 25, 2011 4:06 pm
You aswell eh Doug? :D
I'd love to know what the actual difference(s) is/are between the 1673 and the 1072, or any of them for that matter.
Ian.
dhjj
Unread postby dhjj » Sun Feb 27, 2011 3:41 pm
not sure what the difference is between 1673 and the 1072.
I had one that said 1072 on the board and 1673 on one of the tabs to pop it in and out
mashek
Unread postby mashek » Sun Feb 27, 2011 8:34 pm
The 030-1072-xxx is the part number for the board. The 013-1673-xxx is the assembly that includes the board, the PIMMs, heat sinks, etc.
BTW, the 013-1448-xxx is the same 030-1072-xxx board with 1MB secondary cache PIMMS, smaller heat sinks, etc
Unread postby jan-jaap » Mon Feb 28, 2011 12:32 am
Aha. I had a look at my Onyx IR last night, it has a '1072' board with a date stamp in '98 or '99 (serial number G-something) and R10K rev3.1 CPUs. That dates from well after the O2K was introduced, I couldn't imagine they made a newer rev IP25 after that still.
mapesdhs
Unread postby mapesdhs » Mon Feb 28, 2011 3:12 am
So where on the board would 013-1673-xxx normally be written?
Ian.
mapesdhs@yahoo.com
+44 (0)7434 635 121
dhjj
Unread postby dhjj » Mon Feb 28, 2011 4:48 am
I've only seen it on the plastic tabs used for insertion and removal, (what ever they are called)
I believe my board was rev H, which may be the issue.
And there are 013-1673-101 which as far as I'm concerned are the same board and may indicate memory included, who knows?
mapesdhs
Unread postby mapesdhs » Mon Feb 28, 2011 4:52 am
The board I have says 1072-001 on the insertion tab, and the main 1072 on the PCB is described
as an Assy number, not a PN.
Ian.
mapesdhs@yahoo.com
+44 (0)7434 635 121
Unread postby guardian452 » Mon Feb 28, 2011 5:30 am
Mine has 013-1673-002 on the handle and I'd rather not pull it out just to look for a number. I looked at some pictures I took of the boards a couple years ago but can't find the number. There's one in the gallery here and one on my facebook, so if you know where the part number is you might have better luck than me (both pictures have the top of the board obscured by heatsinks for processors 2 and 3 due to the angle, I suspect that is where the part number is)
I see a 040-1553-001 on the board's frame which I suppose is the part number for the frame lol.
mapesdhs
Unread postby mapesdhs » Mon Feb 28, 2011 7:23 am
Hmm, I guess it varies rather a lot.
Ian.
mapesdhs@yahoo.com
+44 (0)7434 635 121
Unread postby SAQ » Mon Feb 28, 2011 8:30 am
dhjj wrote:I've only seen it on the plastic tabs used for insertion and removal, (what ever they are called)
What memory? Cache?
dhjj
Unread postby dhjj » Mon Feb 28, 2011 9:00 am
no mem, 2mb cache cpus
Unread postby SAQ » Mon Feb 28, 2011 9:08 pm
mashek wrote:The 030-1072-xxx is the part number for the board. The 013-1673-xxx is the assembly that includes the board, the PIMMs, heat sinks, etc.
(PEDANT ALERT)
Everest machines used HIMMs. From a technical perspective there isn't much difference, just the connector and the fact that HIMMS are always single processor modules that can be installed in groups for multiproc IP boards. HIMMS use a Cinch springy wire connector, PIMMS use a pin/socket connector. The Cinch one can be a nightmare to replace if the springy wire bits start to fall out.
Return to “Hardware Wanted”
