sgi visual/video 540 (sd1100), sgi Zx10 VE dm1, SGI PRISM
netman
Unread postby netman » Thu Oct 25, 2007 3:02 pm
Looking to build from different sources or complete systems....they must have their video option cards, the sgi 540 with SD1100, Zx10 VE with dmediapro DM1, the other one i don't even know if sgi even sold any PRISM visualization systems (dmediapro dm12), i think it was one of their later models while they were going down the tubes financially. I'd be curious to know if anyone here has ever owned or even seen a PRISM or Zx10 VE/InterGraph Zx1 system. I've seen Zx10 on ebay but its the server version not Visual workstation....
QuicksilverG4
Re: sgi visual/video 540 (sd1100), sgi Zx10 VE dm1, SGI PRISM
Unread postby QuicksilverG4 » Thu Oct 25, 2007 8:34 pm
netman
Unread postby netman » Tue Oct 30, 2007 10:08 pm
Is that your system on ebay? I saw it but seemed like it was server use only, ie without the dmediapro serial digital card....(looking for systems complete with the video i/o, or dm
video cards alone and put together systems after...)
QuicksilverG4
Unread postby QuicksilverG4 » Wed Oct 31, 2007 1:41 pm
Nope, not mine.
Vagabondo
Unread postby Vagabondo » Fri Nov 02, 2007 12:03 pm
I have a ZX10 I have not used in quite a while and would be willing to part with. I am in St. Louis, MO. Would have to double check specs, but IIRC it is a dual 866PIII with a couple of gigs of ram. Fully functional, and can include a FireGL AGPpro card for vid.
netman
Unread postby netman » Sat Nov 17, 2007 3:57 pm
Hi,Thanks, but sorry I'm only interested in Sgi's that have their video input/output options or if the options are easily found. The SGI Zx10 VE (Visual) system that i was looking for came with Wildcat 4210 and SGI DmediaPRO DM1 card for serial digital video input output. I am also interested in an SGI 540 with the sdi video io, ie sd1100 card.
unixmuseum
Unread postby unixmuseum » Fri Nov 30, 2007 8:36 am
QuicksilverG4 wrote:Nope, not mine.
No, that's Chris from MCE, a hardware reseller in Sunnyvale...
Return to “Hardware Wanted”
