FS: Octane R14k 600MHz - V12
fockion
Unread postby fockion » Tue Apr 24, 2018 12:05 am
Hello,
I am selling my second Octane(2) - Green Skin.
The unit is located in Athens, Greece.
Detailed specs:
# hinv -vm
      PM10600MHZ Board: barcode MCY715     part 030-1774-002 rev  A
            IP30 Board: barcode KJL053     part 030-1467-001 rev  D
             FP1 Board: barcode KBE183     part 030-0891-003 rev  G
    PWR.SPPLY.ER Board: barcode AAE0150158 part 060-0035-002 rev  A
  ODY128VERSIONB Board: barcode LJZ039     part 030-1611-001 rev  C
   FIBRE_CHANNEL Board: barcode JKM842     part 030-0927-003 rev  E
       XT-DIGVID Board: barcode NAR190     part 030-1653-003 rev  C
1 600 MHZ IP30 Processor
Heart ASIC: Revision F
Main memory size: 512 Mbytes
Xbow ASIC: Revision 1.4
Graphics board: V12
and gfxinfo
# ./gfxinfo -vv
        Managed (":0.0") 1920x1200
        BUZZ version B.1
        PB&J version 1
        128MB memory
                Banks: 4, CAS latency: 3
         Monitor 0 type: Unknown
         Video Output: 1920 pixels, 1200 lines, 60.02Hz (1920x1200_60)
         Video Format Flags:  (none)
         Sync Disabled
         Using Gamma Map 0
         Monitor Type:  unknown
         Gain (all color components) - 0.000000 ; range [1,10]
No HDD will be included.
Notice: Allthought the mainboard handle is black, it is as reported a 030-1467-001 rev D.
Please PM for your offers.
Thank you for reading.
:Octane2: 2xR14k 600MHz | 6GB | V12 + DCD
:Octane: R12k 400Mhz | MXE+ PVO
:Indigo2IMP: R4400 250MHz | MAXImpact + IMPACT VIDEO
