Germany - Dualhead Origin 200 max spec
MrWeedster
Unread postby MrWeedster » Wed Jan 31, 2018 7:59 am
Hi.
Theres too much computer stuff in my home, i need to get rid of some.
The first one is a dualhead origin 200 in rack configuration.
Irix 6.5.30f is installed.
It has the hacked driver for the tg1 Gigabit card installed.
Runs great and looks good.
Including the Craylink cable.
I have drive trays for all slots and the blanks.
You'll also get a extra 512MB kit which i think should work.
Hinv:
4 270 MHZ IP27 Processors
CPU 0 at Module 1/Slot 1/Slice A: 270 Mhz MIPS R12000 Processor Chip (enabled)
  Processor revision: 2.3. Scache: Size 4 MB Speed 180 Mhz  Tap 0x9
CPU 1 at Module 1/Slot 1/Slice B: 270 Mhz MIPS R12000 Processor Chip (enabled)
CPU 2 at Module 2/Slot 2/Slice A: 270 Mhz MIPS R12000 Processor Chip (enabled)
CPU 3 at Module 2/Slot 2/Slice B: 270 Mhz MIPS R12000 Processor Chip (enabled)
Main memory size: 3072 Mbytes
Memory at Module 1/Slot 1: 1024 MB (enabled)
  Bank 2 contains 512 MB (Standard) DIMMS (disabled)
  Bank 3 contains 512 MB (Standard) DIMMS (disabled)
Memory at Module 2/Slot 2: 2048 MB (enabled)
Integral SCSI controller 3: Version QL1040B (rev. 2), single ended
  Disk drive: unit 1 on SCSI controller 3 (unit 1)
Integral SCSI controller 4: Version QL1040B (rev. 2), single ended
Integral SCSI controller 2: Version Fibre Channel QL2340, 33 MHz PCI
IOC3/IOC4 serial port: tty3
IOC3/IOC4 serial port: tty4
IOC3 parallel port: plp2
Integral Fast Ethernet: ef0, version 1, module 1, slot MotherBoard, pci 2
Fast Ethernet: ef1, version 1, module 2, slot MotherBoard, pci 2
Gigabit Ethernet: tg1, module 1, PCI bus 0 slot 5
Origin 200 base I/O, module 1 slot 1
Origin 200 base I/O, module 2 slot 2
  PCI Adapter ID (vendor 0x14e4, device 0x1645) PCI slot 5
  PCI Adapter ID (vendor 0x1077, device 0x2312) PCI slot 6
HUB in Module 1/Slot 1: Revision 5 Speed 90.00 Mhz (enabled)
HUB in Module 2/Slot 2: Revision 5 Speed 90.00 Mhz (enabled)
IP27prom in Module 2/Slot n2: Revision 6.156
The door of the upper system does work (One of the hinges is replaced by a screw).
The door of the lower system falls off if you unlock it with the keys.
If you can pick it up around the central bavaria area, i think we'll arrange something about the price.
I have some more for sale if one is willing to come here to get it: A standard Octane 1, a broken Indigo, a Netapp DS14mk2 shelf with 146GB disks and two 19" x86 servers.
Intuition
Re: Germany - Dualhead Origin 200 max spec
Unread postby Intuition » Wed Jan 31, 2018 10:01 am
Very nice. It is very rare to see such great condition Origin 200s.
Also setup for Cray link AND Max spec to boot.
Oh if I were in Germany. :shock:
Image O2 - 300mhz
aka Casey Christopher
