FS: Onyx350 IR3: 4x800MHz | 8GB | 4xRM10 | DG5-2/TVO
Unread postby recondas » Thu Sep 07, 2017 6:15 pm
For Sale: Onyx350 IR3.
Currently installed in a full height Onyx2 rack (included with system).
The compute module is a quad 800MHz Origin350 (has Origin 350 badging) with 8 GB of RAM.,
It has a the IO9, a DM-10 / M-Audio Revolution 7.1 audio board, and a USB card (for kb&m)
in the PCI riser.
The Graphics are InfiniteReality 3. The Graphics Module has a GE16, four RM10s, a Ktown2, and
DG5-2/TVO (the HD Graphics-to-Video option board). The DMedia Video Break-Out Box that
goes with the TVO option is included. I'll also include a number of spare InfiniteReality option boards,
including a pair of DG5-2DPlex boards, an DG5-2/GVO (which is SD rather than HD), a couple of RM9s
(think I have a complete IR2 board set, but I'll have to check on that), and a spare Ktown2.
The system includes an rack-mounted L2 controller (without touch display); I use the L2 to initiate
the full system power up sequence. The L2 is powered by a household-wall-socket-friendly
wall-wart power supply.
The system is installed in an Onyx2 full-height rack which includes the side panels and top hat. I've added an
O3k-style Power Distribution Unit (you could think of the PDU as a rack-mounted surge-strip minus the surge
protection). It connects to a 220/230V and provides 10 three-prong female outlets. The O350 compute
module, the L2 Controller and the tape drive enclosure have switched power supplies and will run on either
110/115V or 220/230V power. The Graphics Module requires 220/230V power, and it can't be run through the
PDU, so if you want to connect the Graphics Module and the PDU you'll need *two* 220/230V 30A outlets.
Both currently have the NEMA L6-30 twist-lock connectors that SGI shipped with 220/230V systems for the
US/Canadian markets.
The system includes an Ultrium2 tape drive (in a Dell PowerVault 114T rack-mount enclosure).
I've attached an hinv/gfxinfo/env/serial all; there are a few additional details and a few (dated) photos
in the original hinv thread.
I'm asking a thousand dollars for the system. I realize I could probably double that if I was
willing to break it up and sell it in pieces, but I spent *a lot* of time and effort on the system
and would like to see it live on (so please don't ask if I'd sell parts).
Because of the size of the unit and the number of spares included, shipping wouldn't probably be
practical, so I''ll start out asking for a "collection-only" sale.
If anyone does decide to contact me, please be patient while awaiting a response. I'm not able
to get by here as often as I used to.
 hinv -vm
       IP53_4CPU Board: barcode NGA768     part 030-1959-002 rev -B
          KTOWN2 Board: barcode LZP881     part 030-1593-001 rev  G
          GE16-4 Board: barcode GMX327     part 030-1398-001 rev  A
       2U_INT_53 Board: barcode NXR118     part 030-1809-006 rev -C
             IO9 Board: barcode NYL142     part 030-1771-006 rev -A
4 800 MHZ IP35 Processors
CPU 0 at Module 001c01/Slot 0/Slice A: 800 Mhz MIPS R16000 Processor Chip (enabled)
  Processor revision: 2.2. Scache: Size 8 MB Speed 400 Mhz  Tap 0xa
CPU 1 at Module 001c01/Slot 0/Slice B: 800 Mhz MIPS R16000 Processor Chip (enabled)
CPU 2 at Module 001c01/Slot 0/Slice C: 800 Mhz MIPS R16000 Processor Chip (enabled)
CPU 3 at Module 001c01/Slot 0/Slice D: 800 Mhz MIPS R16000 Processor Chip (enabled)
Main memory size: 8192 Mbytes
  CDROM: unit 3 on SCSI controller 1
IOC3/IOC4 serial port: tty3
IOC3/IOC4 serial port: tty4
IOC3/IOC4 serial port: tty5
IOC3/IOC4 serial port: tty6
Graphics board: InfiniteReality3
  PCI Adapter ID (vendor 0x1412, device 0x1724) PCI slot 1
  PCI Adapter ID (vendor 0x1033, device 0x0035) PCI slot 2
  PCI Adapter ID (vendor 0x1033, device 0x00e0) PCI slot 2
IOC4 firmware revision 83
USB controller: type OHCI
 /usr/gfx/gfxinfo -v
Graphics board 0 is "KONAD" graphics.
        Managed (":0.0") 1920x1200
        Display has 2 channels
        4 GEs (of 4), occmask = 0x0f
        4 RM10 boards (of 4) 1/1/1/1
        Texture Memory: 256MB/256MB/256MB/256MB
        Large pixel depth
        32K cmap
        TVO option detected
        brd: 80f61806 3041606/3041606/3041606/3041606 f9191002
        rm0: 15032057 15431057
              4631057 2/2/2/2
              4d31057 2/2/2/2/2/2/2/2
              4938057 5/5/5/5/5/5/5/5/5/5/5/5/5/5/5/5/5/5/5/5
        rm1: 15032057 15431057
              4631057 2/2/2/2
        rm2: 15032057 15431057
              4631057 2/2/2/2
        rm3: 15032057 15431057
              4631057 2/2/2/2
         dg: 05532057
              5838057 1/1/1/1
              5631057 1/1
        GE:   NIC #:      0000.002a.e59b (family: 0b)
              Serial #:   GMX327
              Part #:     030-1398-001
        KT:   NIC #:      0000.003f.d1c6 (family: 0b)
              Serial #:   LZP881
              Part #:     030-1593-001
        RM0:  NIC #:      0000.005a.1d9b (family: 0b)
              Serial #:   KHM199
              Part #:     030-1402-001
        TM0:  NIC #:      0000.005a.1e8b (family: 0b)
              Serial #:   MJN014
              Part #:     030-1588-001
        RM1:  NIC #:      0000.0059.0bf3 (family: 0b)
              Serial #:   MHG599
        TM1:  NIC #:      0000.005a.1ade (family: 0b)
              Serial #:   MJN010
        RM2:  NIC #:      0000.0048.28b3 (family: 0b)
              Serial #:   LET794
        TM2:  NIC #:      0000.0048.ec21 (family: 0b)
              Serial #:   LEW623
        RM3:  NIC #:      0000.0048.24e6 (family: 0b)
              Serial #:   LET798
        TM3:  NIC #:      0000.0048.9f17 (family: 0b)
              Serial #:   LEX312
        BP:   No NIC serial number available.
        DG:   NIC #:      0000.0059.c878 (family: 0b)
              Serial #:   MJS686
              Part #:     030-1242-001
        DGOPT:NIC #:      0000.0048.0f1e (family: 0b)
              Serial #:   MJS663
              Part #:     030-1511-004
         Video Output: 1920 pixels, 1200 lines, 60.00Hz (IR_1920x1200_60rb.vfo)
         Video Format Flags:  (none)
         Sync Output(s):
          Composite sync on Green
          Composite TTL sync on Aux 0
         Using Gamma Map 0
        Channel 1:
         Video Output: 1280 pixels, 1024 lines, 60.00Hz (1280x1024_60.vfo)
         Sync Output(s):
         Using Gamma Map 0
 l1cmd version
L1 1.48.1 (Image B), Built 01/22/2007 11:34:34    [MIPS 2MB image]
 l1cmd pci
Bus Slot Stat    Power Mode/Speed
  1    1 0x80 01   15W PCI   66MHz
  1    2 0x80 0f  none PCI   66MHz
  2    1 0x00 00  7.5W PCI   33MHz
  2    2 0x00 01   15W PCI   33MHz
l2cmd env
001c01:
          1.8V    Enabled  10%   1.62/  1.98  20%   1.44/  2.16    1.777
           12V <not present>
        12V #2    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.063
          3.3V    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.320
        12V IO    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.063
        5V AUX    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    5.044
      3.3V AUX    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.285
    PCI 5V AUX    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    5.070
      PCI 3.3V    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.302
      PCI 2.5V    Enabled  10%   2.25/  2.75  20%   2.00/  3.00    2.509
        PCI 5V    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    4.966
  XIO 12V BIAS <not present>
        XIO 5V <not present>
      XIO 2.5V <not present>
  XIO 3.3V AUX <not present>
 IP53 3.3V AUX    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.302
   IP53 5V AUX    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    5.070
      IP53 12V    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.000
     IP53 VCPU    Enabled  10%   1.13/  1.38  20%   1.00/  1.50    1.241
     IP53 SRAM    Enabled  10%   2.25/  2.75  20%   2.00/  3.00    2.483
     IP53 1.5V    Enabled  10%   1.35/  1.65  20%   1.20/  1.80    1.495
FAN  0  EXHST 1    Enabled         1980         2235
FAN  1  EXHST 2    Enabled         1980         2235
FAN  2       PS    Enabled         3200         4891
FAN  3    PCI 1    Enabled         1980         2960
FAN  4    PCI 2    Enabled         1980         2678
 0 INTERFACE 0       Enabled   31C/ 87F   48C/118F   55C/131F   18C/ 64F
 1 INTERFACE 1       Enabled   31C/ 87F   48C/118F   55C/131F   19C/ 66F
 2 INTERFACE 2       Enabled   31C/ 87F   48C/118F   55C/131F   20C/ 68F
 3 PCI RISER         Enabled   31C/ 87F   48C/118F   55C/131F   20C/ 68F
 4 ODYSSEY        <not present>
 5 NODE              Enabled   31C/ 87F   48C/118F   55C/131F   18C/ 64F
 6 BEDROCK           Enabled   31C/ 87F   48C/118F   55C/131F   19C/ 66F
001g02:
        5V aux    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    5.07
      3.3V aux    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.34
FAN 0   BLOWER    Enabled         1080         1476
L1                Enabled   30C/ 86F   35C/ 95F   40C/104F   22C/ 71F
l2cmd serial all
001c01:
Local System Serial Number      NVRAM         M2005911
Reference System Serial Number  NVRAM         M2005911
Local Brick Serial Number       EEPROM        NXR118
Reference Brick Serial Number   NVRAM         NXR118
INTERFACE   2U_INT_53       NXR118         030_1809_006          C    00
IO9         IO9             NYL142         030_1771_006          A    00
ODYSSEY     no hardware detected
RISER       2U_RISER        NWE435         030_1808_006          C    00
NODE        IP53_4CPU       NGA768         030_1959_002          B    00
PS 1        no hardware detected
PS 2        DPS-500EBE      XPD0601000375  060-0178-003          S4
DIMM 0     CE000000000000000C9B1200 M3 47L6423DT2-CA0   2D   10.0  N/A
DIMM 2     CE000000000000000C9A1200 M3 47L6423DT2-CA0   2D   10.0  N/A
DIMM 4     CE000000000000000CA21200 M3 47L6423DT2-CA0   2D   10.0  N/A
DIMM 6     CE000000000000000C9E1200 M3 47L6423DT2-CA0   2D   10.0  N/A
DIMM 1     CE000000000000000CCE1200 M3 47L6423DT2-CA0   2D   10.0  N/A
DIMM 3     CE000000000000000CCC1200 M3 47L6423DT2-CA0   2D   10.0  N/A
DIMM 5     CE000000000000000CCA1200 M3 47L6423DT2-CA0   2D   10.0  N/A
DIMM 7     CE000000000000000CD61200 M3 47L6423DT2-CA0   2D   10.0  N/A
001g02:
Reference System Serial Number  Attached L2   M2005911
Local Brick Serial Number       EEPROM        MAC956
Reference Brick Serial Number   NVRAM         MAC956
ID          KCARL1          MAC956      030_1598_004          A    00
 diskpatch -v
sc0d1l0:  Disk         SGI     ST373307LC      2743  Serial: 3HZA3PQK
sc0d2l0:  Disk         FUJITSU MAS3735NC       5B08  Serial: A107P480
 uname -aR
IRIX64 fyrestorm 6.5 6.5.30f 07202013 IP35
HurricaneJames
Re: FS: Onyx350 IR3: 4x800MHz | 8GB | 4xRM10 | DG5-2/TVO
Unread postby HurricaneJames » Thu Sep 07, 2017 8:46 pm
That would be so sweet, and the price is really decent, but it would cost more than that per month to lease the extra space for me to have it :cry:
Irinikus
Unread postby Irinikus » Thu Sep 07, 2017 8:55 pm
Right now, I wish I lived in the US! :(
BTW, why are you selling?
Image ... Image
mopar5150
Unread postby mopar5150 » Fri Sep 08, 2017 9:11 am
To whoever buys this system. I will give you a free upgrade with GE-16, 2 RM11s and the IR4 front labels. Just pay shipping.
:Tezro: :O3x0: :A350:
jebmayers
Unread postby jebmayers » Fri Sep 08, 2017 10:06 am
mopar5150 wrote:To whoever buys this system. I will give you a free upgrade with GE-16, 2 RM11s and the IR4 front labels. Just pay shipping.
Now I really really wish I lived in the states! ;o)
Jeb
