900Mhz Fuel and Octane 2 husk for sale
Sean4000
Unread postby Sean4000 » Sun Aug 13, 2017 10:21 pm
Fuel and Octane 2 for sale
Fuel has v12 graphics, 4gb ram, SCSI to SSD adapter but no hdd, and a 900 mhz cpu.
Octane 2 is a husk. No drives and mounts, ram, cpu, or graphics. Does come with several cherokee PSUs.
I'm in New Orleans and looking to deliver.
HurricaneJames
Re: 900Mhz Fuel and Octane 2 husk for sale
Unread postby HurricaneJames » Mon Aug 14, 2017 5:39 am
I might be interested. How much are you looking to get and do you have any pictures?
Sean4000
Unread postby Sean4000 » Mon Aug 14, 2017 4:12 pm
I will have plenty of photos uploaded when I return home after work.
Sean4000
Unread postby Sean4000 » Mon Aug 14, 2017 5:40 pm
Fuel front
Sean4000
Unread postby Sean4000 » Mon Aug 14, 2017 6:09 pm
The insides are very clean and kept in a smoke free environment.
Sean4000
Unread postby Sean4000 » Mon Aug 14, 2017 6:12 pm
4X1GB Memory modules
Sean4000
Unread postby Sean4000 » Sat Sep 02, 2017 9:39 pm
i powered the system up and I get a solid red light then it blinks white and no image displays on the screen. I'm sorry for no posting this earlier but I've been very busy.
Sean4000
Unread postby Sean4000 » Sat Sep 02, 2017 10:16 pm
if anyone can help me get it to post so i can get a hinv, i'd appreciate it. then i can get a more accurate price.
Hombre71
Unread postby Hombre71 » Sat Sep 02, 2017 11:09 pm
Sean4000 wrote:if anyone can help me get it to post so i can get a hinv, i'd appreciate it. then i can get a more accurate price.
Connect a serial cable to the L1 port on the mb to get better diagnostics out.
Just search the forum for L1 and Fuel.38400 baud.
mazzinia
Unread postby mazzinia » Sun Sep 03, 2017 2:24 am
sometimes a fuel doesn't like a keyboard and/or mouse , it's enough for a red light.
If you have any other spare kb/ms , may be worth a try
Unread postby Trippynet » Sun Sep 03, 2017 4:13 am
Sean4000 wrote:i powered the system up and I get a solid red light then it blinks white and no image displays on the screen. I'm sorry for no posting this earlier but I've been very busy.
How long did you leave it running? The red LED to start with is normal, then the blinking white LED is the system performing its POST. It's common for it to blink white for 30 seconds to a minute if there's a lot of RAM/hardware installed. Eventually after a while, the LED should turn solid white. Only at this time will anything appear on the display.
Sean4000
Unread postby Sean4000 » Tue Sep 05, 2017 8:24 pm
Hey guys,
I let it boot for 2 minutes after powering on. Nothing appeared on the screen and the light now alternates between red and white. I am ordering a null modem cable and hope to results within the next 2 days.
Unread postby Trippynet » Wed Sep 06, 2017 12:36 am
According to the Fuel manual, a blinking red/white lightbar means "Graphics configuration error".
Fuels can be finicky systems, you could try removing and re-seating the graphics card to see if this will help. Failing that, your null modem cable should hopefully provide more info once it arrives.
mazzinia
Unread postby mazzinia » Wed Sep 06, 2017 8:39 am
Actually, what kind of monitor did you attach ? (resolution)
