FS: [sold] (Octane2 2xR12k400, 2GB, V12) [Still Available] DM2 + VBOB
fockion
Unread postby fockion » Wed Apr 13, 2016 11:51 pm
HI!,
For sale an Octane2 in fully working condition with the following specs.
It has some minor scratches on the top of the machine, otherwise it is in good cosmetic condition.
The unit is located in Athens, Greece.
hinv -vm
            PM20 Board: barcode KYA016     part 030-1476-002 rev  B
            IP30 Board: barcode LKD614     part 030-1467-001 rev  D
             FP1 Board: barcode LPE476     part 030-0891-003 rev  H
    PWR.SPPLY.ER Board: barcode AAE1010102 part 060-0035-002 rev  A
  ODY128VERSIONB Board: barcode LJZ039     part 030-1611-001 rev  C
   FIBRE_CHANNEL Board: barcode JKM842     part 030-0927-003 rev  E
       XT-DIGVID Board: barcode NAR190     part 030-1653-003 rev  C
2 400 MHZ IP30 Processors
Heart ASIC: Revision F
Main memory size: 2048 Mbytes
Xbow ASIC: Revision 1.4
Graphics board: V12
  PCI Adapter ID (vendor 0x9004, device 0x1160) PCI slot 0
  PCI Adapter ID (vendor 0x9004, device 0x1160) PCI slot 1
XT-DIGVID Multi-standard Digital Video: controller 1, unit 1, version 0x0
gfxinfo -v
        Managed (":0.0") 1920x1200
        BUZZ version B.1
        PB&J version 1
        128MB memory
                Banks: 4, CAS latency: 3
         Monitor 0 type: Unknown
         Video Output: 1920 pixels, 1200 lines, 60.02Hz (1920x1200_60)
         Video Format Flags:  (none)
         Sync Disabled
         Using Gamma Map 0
For your offers please send me PM.
:Octane2: 2xR14k 600MHz | 6GB | V12 + DCD
:Octane: R12k 400Mhz | MXE+ PVO
:Indigo2IMP: R4400 250MHz | MAXImpact + IMPACT VIDEO
fockion
Re: FS: [sold] (Octane2 2xR12k400, 2GB, V12) [Still Available] DM2 + VBOB
Unread postby fockion » Mon Apr 25, 2016 8:40 pm
[Update]
The Octane2 has been sold. I still have the DM2 + VBOB.
fockion
Unread postby fockion » Fri Sep 22, 2017 9:22 am
DM2 + VBOB still available.
I am including also the confidence tests.
# ./xtdigvid_confidence
***        XTDIGVID_CONFIDENCE ===== XTDIGVID_CONFIDENCE          ***
System type is: OCTANE2
System has 1 CPUs and 1024MB of memory
Found 1 XTDIGVID board(s)
Starting xtdigvid_confidence script ......
Total XTDIGVID boards in the system is 1 board(s).
Test will run for 1 loop(s).
Board(s) information:
  XT-DIGVID plugged in /hw/node/xtalk/9
    (Part number is 030-1653-003, Rev C), Serial number NAR190
>>>>> PLEASE NOTE ABOUT PART NUMBERS <<<<<
>>>>> Each part number above corresponds to an XTDIGVID board.
==> Please verify that each board information is correct.
==> Verify that the total board reporting number matches
==> the number of boards installed.  Are they matched ? (y/n): y
Continuing with the xtdigvid_confidence......
Running standard XTDIGVIDTST tests.
INSTRUCTION:
   1) Connect a LVDS cable from the xtdigvid connector labelled P1
      to the VBOB connector labelled P1.
   2) Connect a LVDS cable from the xtdigvid connector labelled P2
      to the VBOB connector labelled P2.
   3) On the VBOB, connect a coax from 'HD out 1' to 'HD in 1'.
                   connect a coax from 'HD out 2' to 'HD in 2'.
   4) On the VBOB, connect a coax from 'SD out 1' to 'SD in 1'.
                   connect a coax from 'SD out 2' to 'SD in 2'.
Is everything ready <y/n>?: y
==> Continuing ...
xtdigvid_confidence script will run approximately 10 minutes (per XTDIGVID board per lo
op)
Looping 1 time(s) .....
Test log for board IRIX devnum 0 is /usr/tmp/XTDIGVID_logs/xtdigvid_confidence.log0.17-
07-19_02.56
Found Irix boardnum 0 plugged in /hw/node/xtalk/9
    XT-DIGVID (Part number 030-1653-003, Rev C), Serial number NAR190
mldaemon is running...
----- TESTING BOARD 0 -----
       UST INCREMENT CORRECTNESS CHECK
Checking output path UST ...
Running command npri -s RR -r 100 /usr/diags/ml_xtdigvid/bin/dv_memtovid  -d xt-digvid
-B 0 \
              -t ML_TIMING_525 \
              -v ML_COLORSPACE_CbYCr_601_HEAD \
              -i 8 \
              -S ML_SAMPLING_422 \
              -p ML_PACKING_8 \
              -s ML_SAMPLING_422 \
              -m ML_COLORSPACE_CbYCr_601_HEAD \
              -l ML_INTERLEAVE_MODE_INTERLEAVED \
              -D ML_DOMINANCE_F1 \
              -o ML_ORIENTATION_TOP_TO_BOTTOM \
              -G XTDIGVID_GENLOCK_SRC_TYPE_INTERNAL \
              -b 20 \
              -f /usr/diags/ml_xtdigvid/bin/testpattern/tpat525.yuv \
              -M
transfer complete: length:701280 MSC:104 deltaMSC:2 UST:0x0000008cc79f99e0 deltaUST:333
66720
transfer complete: length:701280 MSC:106 deltaMSC:2 UST:0x0000008cc99cb8e0 deltaUST:333
65760
transfer complete: length:701280 MSC:108 deltaMSC:2 UST:0x0000008ccb99d7e0 deltaUST:333
65760
transfer complete: length:701280 MSC:110 deltaMSC:2 UST:0x0000008ccd96f6e0 deltaUST:333
65760
transfer complete: length:701280 MSC:112 deltaMSC:2 UST:0x0000008ccf9415e0 deltaUST:333
65760
transfer complete: length:701280 MSC:114 deltaMSC:2 UST:0x0000008cd19138a0 deltaUST:333
66720
transfer complete: length:701280 MSC:116 deltaMSC:2 UST:0x0000008cd38e57a0 deltaUST:333
65760
transfer complete: length:701280 MSC:118 deltaMSC:2 UST:0x0000008cd58b76a0 deltaUST:333
65760
transfer complete: length:701280 MSC:120 deltaMSC:2 UST:0x0000008cd78895a0 deltaUST:333
65760
transfer complete: length:701280 MSC:122 deltaMSC:2 UST:0x0000008cd985b4a0 deltaUST:333
65760
transfer complete: length:701280 MSC:124 deltaMSC:2 UST:0x0000008cdb82d760 deltaUST:333
66720
transfer complete: length:701280 MSC:126 deltaMSC:2 UST:0x0000008cdd7ff660 deltaUST:333
65760
transfer complete: length:701280 MSC:128 deltaMSC:2 UST:0x0000008cdf7d1560 deltaUST:333
65760
transfer complete: length:701280 MSC:130 deltaMSC:2 UST:0x0000008ce17a3460 deltaUST:333
65760
transfer complete: length:701280 MSC:132 deltaMSC:2 UST:0x0000008ce3775360 deltaUST:333
65760
transfer complete: length:701280 MSC:134 deltaMSC:2 UST:0x0000008ce5747620 deltaUST:333
66720
transfer complete: length:701280 MSC:136 deltaMSC:2 UST:0x0000008ce7719520 deltaUST:333
65760
transfer complete: length:701280 MSC:138 deltaMSC:2 UST:0x0000008ce96eb420 deltaUST:333
65760
transfer complete: length:701280 MSC:140 deltaMSC:2 UST:0x0000008ceb6bd320 deltaUST:333
65760
UST Tolerance is 8000
UST Delta = 33370000
MSC Delta = 2
**************** Checking ust/msc *****************
Last msc checked is 122
Status is 0; (0=passed; 1=failed)
UST variance error count is 0
PASS: ML Output path UST check.
   SD 525   720x487  59.94i LOOPBACK TEST W/ INTERNAL GENLOCK
Starting video output on UUT...
Running command: npri -s RR -r 100 /usr/diags/ml_xtdigvid/bin/dv_memtovid  -d xt-digvid
 -B 0 \
              -t ML_TIMING_525 \
              -i 8 \
              -p ML_PACKING_8 \
              -I XTDIGVID_GENLOCK_TIMING_AUTODETECT \
              -b 1200 \
              -e /usr/diags/ml_xtdigvid/bin/tmp/memtovid_status \
              -F /usr/diags/ml_xtdigvid/bin/tmp/525bufout
[1] 1546
memtovid_status = 0
Starting video input on UUT...
Running command: npri -s RR -r 100 /usr/diags/ml_xtdigvid/bin/dv_vidtomem  -d xt-digvid -B 0
              -t ML_TIMING_525 \
              -i 8 \
              -p ML_PACKING_8 \
              -b 4 \
              -f /usr/diags/ml_xtdigvid/bin/tmp/cap525 \
              -E /usr/diags/ml_xtdigvid/bin/tmp/memtovid_status \
              -F /usr/diags/ml_xtdigvid/bin/tmp/525bufin
timing: ML_TIMING_525
        videoWidth: 720
        videoStartY_f1: 20
        videoHeightf1: 244
        videoStartY_f2: 283
        videoHeightf2: 243
        imageWidth = 720
        imageHeight1 = 244
        imageHeight2 = 243
/usr/diags/ml_xtdigvid/bin/dv_vidtomem.1553 image buffer size = 701280
Wed Jul 19 02:57:03 BST 2017
/usr/diags/ml_xtdigvid/bin/dv_vidtomem.1553: NOTICE: VIDEO_SIGNAL_PRESENT:
        ML_VIDEO_SIGNAL_PRESENT_INT32 = ML_TIMING_525
/usr/diags/ml_xtdigvid/bin/dv_vidtomem.1553: receiving buffers:...4
/usr/diags/ml_xtdigvid/bin/dv_vidtomem.1553: 4 buffers transferred
/usr/diags/ml_xtdigvid/bin/dv_vidtomem.1553: shutdown pending
/usr/diags/ml_xtdigvid/bin/dv_vidtomem.1553: Saving files...
Saving image in /usr/diags/ml_xtdigvid/bin/tmp/525bufin_00001.yuv
Saving image in /usr/diags/ml_xtdigvid/bin/tmp/525bufin_00002.yuv
Saving image in /usr/diags/ml_xtdigvid/bin/tmp/525bufin_00003.yuv
Saving image in /usr/diags/ml_xtdigvid/bin/tmp/525bufin_00004.yuv
/usr/diags/ml_xtdigvid/bin/dv_vidtomem.1553: shutdown complete: exit_status = 0
Wed Jul 19 02:57:09 BST 2017
diff_status = 0
56623 1370 /usr/diags/ml_xtdigvid/bin/tmp/525bufout
56623 1370 /usr/diags/ml_xtdigvid/bin/tmp/525bufin_00001.yuv
diff_status = 0
56623 1370 /usr/diags/ml_xtdigvid/bin/tmp/525bufin_00002.yuv
diff_status = 0
56623 1370 /usr/diags/ml_xtdigvid/bin/tmp/525bufin_00003.yuv
diff_status = 0
56623 1370 /usr/diags/ml_xtdigvid/bin/tmp/525bufin_00004.yuv
memtovid output
        videoWidth    : 720
        videoStartY_f1: 20
        videoHeightf1 : 244
        videoStartY_f2: 283
        videoHeightf2 : 243
        imageWidth = 720
        imageHeight1 = 244
        imageHeight2 = 243
readYUVimage: file /usr/diags/ml_xtdigvid/bin/testpattern/tpat525.yuv, xsize = 720,  ysize =
 487
/usr/diags/ml_xtdigvid/bin/dv_memtovid.1546: image buffer size = 701280
/usr/diags/ml_xtdigvid/bin/dv_memtovid.1546: filling buffers.......
Wed Jul 19 02:56:56 BST 2017
/usr/diags/ml_xtdigvid/bin/dv_memtovid.1546: Saving reference filename = /usr/diags/ml_xtdig
/usr/diags/ml_xtdigvid/bin/dv_memtovid.1546: transferring buffers:...100...200...300...400
PASS: ML_TIMING_525 loopback test with internal genlock passed.
[1]  + Killed               ( $MEMTOVID -d $DEVICE_NAME -B $this_device -t $timing_out -v  .
Waiting for memtovid to complete ...
   HD 1080i 1920x1080 5994i LOOPBACK TEST W/ INTERNAL GENLOCK
Running command: npri -s RR -r 100 /usr/diags/ml_xtdigvid/bin/dv_memtovid  -d xt-digvid -B 0
              -t ML_TIMING_1125_1920x1080_5994i \
              -i 8 \
              -p ML_PACKING_8 \
              -b 1200 \
              -f /usr/diags/ml_xtdigvid/bin/testpattern/tpat1080.yuv \
              -F /usr/diags/ml_xtdigvid/bin/tmp/1080bufout
[1] 1607
              -i 8 \
              -p ML_PACKING_8 \
              -b 4 \
              -f /usr/diags/ml_xtdigvid/bin/tmp/cap1080 \
              -F /usr/diags/ml_xtdigvid/bin/tmp/1080bufin
timing: ML_TIMING_1125_1920x1080_5994i
        videoWidth: 1920
        videoStartY_f1: 21
        videoHeightf1: 540
        videoStartY_f2: 584
        videoHeightf2: 540
        imageWidth = 1920
        imageHeight1 = 540
        imageHeight2 = 540
/usr/diags/ml_xtdigvid/bin/dv_vidtomem.1614 image buffer size = 4147200
Wed Jul 19 02:57:37 BST 2017
/usr/diags/ml_xtdigvid/bin/dv_vidtomem.1614: NOTICE: VIDEO_SIGNAL_PRESENT:
        ML_VIDEO_SIGNAL_PRESENT_INT32 = ML_TIMING_1125_1920x1080_5994i
/usr/diags/ml_xtdigvid/bin/dv_vidtomem.1614: receiving buffers:...4
/usr/diags/ml_xtdigvid/bin/dv_vidtomem.1614: 4 buffers transferred
/usr/diags/ml_xtdigvid/bin/dv_vidtomem.1614: shutdown pending
/usr/diags/ml_xtdigvid/bin/dv_vidtomem.1614: Saving files...
Saving image in /usr/diags/ml_xtdigvid/bin/tmp/1080bufin_00001.yuv
Saving image in /usr/diags/ml_xtdigvid/bin/tmp/1080bufin_00002.yuv
Saving image in /usr/diags/ml_xtdigvid/bin/tmp/1080bufin_00003.yuv
Saving image in /usr/diags/ml_xtdigvid/bin/tmp/1080bufin_00004.yuv
/usr/diags/ml_xtdigvid/bin/dv_vidtomem.1614: shutdown complete: exit_status = 0
Wed Jul 19 02:57:42 BST 2017
vidtomem_status = 0
diff_status = 0
47457 8100 /usr/diags/ml_xtdigvid/bin/tmp/1080bufout
47457 8100 /usr/diags/ml_xtdigvid/bin/tmp/1080bufin_00001.yuv
diff_status = 0
47457 8100 /usr/diags/ml_xtdigvid/bin/tmp/1080bufin_00002.yuv
diff_status = 0
47457 8100 /usr/diags/ml_xtdigvid/bin/tmp/1080bufin_00003.yuv
diff_status = 0
47457 8100 /usr/diags/ml_xtdigvid/bin/tmp/1080bufin_00004.yuv
memtovid output
        videoWidth    : 1920
        videoStartY_f1: 21
        videoHeightf1 : 540
        videoStartY_f2: 584
        videoHeightf2 : 540
        imageWidth = 1920
        imageHeight1 = 540
        imageHeight2 = 540
readYUVimage: file /usr/diags/ml_xtdigvid/bin/testpattern/tpat1080.yuv, xsize = 1920,  ysize
 = 1080
/usr/diags/ml_xtdigvid/bin/dv_memtovid.1607: image buffer size = 4147200
/usr/diags/ml_xtdigvid/bin/dv_memtovid.1607: filling buffers.......
Wed Jul 19 02:57:22 BST 2017
/usr/diags/ml_xtdigvid/bin/dv_memtovid.1607: Saving reference filename = /usr/diags/ml_xtdig
/usr/diags/ml_xtdigvid/bin/dv_memtovid.1607: transferring buffers:...100...200...300...400..
.500
PASS: ML_TIMING_1125_1920x1080_5994i loopback test w/ internal genlock passed.
   HD 720p  1280x720    60P LOOPBACK TEST W/ INTERNAL GENLOCK
              -t ML_TIMING_750_1280x720_60p \
              -v ML_COLORSPACE_CbYCr_709_HEAD \
              -i 8 \
              -p ML_PACKING_8 \
              -m ML_COLORSPACE_CbYCr_709_HEAD \
              -b 1200 \
              -f /usr/diags/ml_xtdigvid/bin/testpattern/tpat720p.yuv \
              -F /usr/diags/ml_xtdigvid/bin/tmp/720pbufout
[1] 1681
              -i 8 \
              -p ML_PACKING_8 \
              -b 4 \
              -f /usr/diags/ml_xtdigvid/bin/tmp/cap720p \
              -F /usr/diags/ml_xtdigvid/bin/tmp/720pbufin
timing: ML_TIMING_750_1280x720_60p
        videoWidth: 1280
        videoStartY_f1: 26
        videoHeightf1: 720
        videoStartY_f2: 0
        videoHeightf2: 0
        imageWidth = 1280
        imageHeight1 = 720
        imageHeight2 = 0
/usr/diags/ml_xtdigvid/bin/dv_vidtomem.1688 image buffer size = 1843200
Wed Jul 19 02:58:09 BST 2017
/usr/diags/ml_xtdigvid/bin/dv_vidtomem.1688: NOTICE: VIDEO_SIGNAL_PRESENT:
        ML_VIDEO_SIGNAL_PRESENT_INT32 = ML_TIMING_750_1280x720_60p
/usr/diags/ml_xtdigvid/bin/dv_vidtomem.1688: receiving buffers:...4
/usr/diags/ml_xtdigvid/bin/dv_vidtomem.1688: 4 buffers transferred
/usr/diags/ml_xtdigvid/bin/dv_vidtomem.1688: shutdown pending
/usr/diags/ml_xtdigvid/bin/dv_vidtomem.1688: Saving files...
Saving image in /usr/diags/ml_xtdigvid/bin/tmp/720pbufin_00001.yuv
Saving image in /usr/diags/ml_xtdigvid/bin/tmp/720pbufin_00002.yuv
Saving image in /usr/diags/ml_xtdigvid/bin/tmp/720pbufin_00003.yuv
Saving image in /usr/diags/ml_xtdigvid/bin/tmp/720pbufin_00004.yuv
/usr/diags/ml_xtdigvid/bin/dv_vidtomem.1688: shutdown complete: exit_status = 0
Wed Jul 19 02:58:13 BST 2017
vidtomem_status = 0
diff_status = 0
36211 3600 /usr/diags/ml_xtdigvid/bin/tmp/720pbufout
36211 3600 /usr/diags/ml_xtdigvid/bin/tmp/720pbufin_00001.yuv
diff_status = 0
36211 3600 /usr/diags/ml_xtdigvid/bin/tmp/720pbufin_00002.yuv
diff_status = 0
36211 3600 /usr/diags/ml_xtdigvid/bin/tmp/720pbufin_00003.yuv
diff_status = 0
36211 3600 /usr/diags/ml_xtdigvid/bin/tmp/720pbufin_00004.yuv
memtovid output
        videoWidth    : 1280
        videoStartY_f1: 26
        videoHeightf1 : 720
        videoStartY_f2: 0
        videoHeightf2 : 0
        imageWidth = 1280
        imageHeight1 = 720
        imageHeight2 = 0
readYUVimage: file /usr/diags/ml_xtdigvid/bin/testpattern/tpat720p.yuv, xsize = 1280,  ysize
 = 720
/usr/diags/ml_xtdigvid/bin/dv_memtovid.1681: image buffer size = 1843200
/usr/diags/ml_xtdigvid/bin/dv_memtovid.1681: filling buffers.......
Wed Jul 19 02:57:54 BST 2017
/usr/diags/ml_xtdigvid/bin/dv_memtovid.1681: Saving reference filename = /usr/diags/ml_xtdig
/usr/diags/ml_xtdigvid/bin/dv_memtovid.1681: transferring buffers:...100...200...300...400..
.500...600...700...800...900...1000...1100
PASS: ML_TIMING_750_1280x720_60p loopback test w/ internal genlock passed.
   SD 625   720x576     50i LOOPBACK TEST W/ INTERNAL GENLOCK
              -t ML_TIMING_625 \
              -i 8 \
              -p ML_PACKING_8 \
              -b 1200 \
              -f /usr/diags/ml_xtdigvid/bin/testpattern/tpat625.yuv \
              -F /usr/diags/ml_xtdigvid/bin/tmp/625bufout
[1] 1754
              -t ML_TIMING_625 \
              -i 8 \
              -p ML_PACKING_8 \
              -b 4 \
              -f /usr/diags/ml_xtdigvid/bin/tmp/cap625 \
              -F /usr/diags/ml_xtdigvid/bin/tmp/625bufin
timing: ML_TIMING_625
        videoWidth: 720
        videoStartY_f1: 23
        videoHeightf1: 288
        videoStartY_f2: 336
        videoHeightf2: 288
        imageWidth = 720
        imageHeight1 = 288
        imageHeight2 = 288
/usr/diags/ml_xtdigvid/bin/dv_vidtomem.1761 image buffer size = 829440
Wed Jul 19 02:58:26 BST 2017
/usr/diags/ml_xtdigvid/bin/dv_vidtomem.1761: NOTICE: VIDEO_SIGNAL_PRESENT:
        ML_VIDEO_SIGNAL_PRESENT_INT32 = ML_TIMING_625
/usr/diags/ml_xtdigvid/bin/dv_vidtomem.1761: receiving buffers:...4
/usr/diags/ml_xtdigvid/bin/dv_vidtomem.1761: 4 buffers transferred
/usr/diags/ml_xtdigvid/bin/dv_vidtomem.1761: shutdown pending
/usr/diags/ml_xtdigvid/bin/dv_vidtomem.1761: Saving files...
Saving image in /usr/diags/ml_xtdigvid/bin/tmp/625bufin_00001.yuv
Saving image in /usr/diags/ml_xtdigvid/bin/tmp/625bufin_00002.yuv
Saving image in /usr/diags/ml_xtdigvid/bin/tmp/625bufin_00003.yuv
Saving image in /usr/diags/ml_xtdigvid/bin/tmp/625bufin_00004.yuv
/usr/diags/ml_xtdigvid/bin/dv_vidtomem.1761: shutdown complete: exit_status = 0
Wed Jul 19 02:58:32 BST 2017
memtovid output
        videoWidth    : 720
        videoStartY_f1: 23
        videoHeightf1 : 288
        videoStartY_f2: 336
        videoHeightf2 : 288
        imageWidth = 720
        imageHeight1 = 288
        imageHeight2 = 288
readYUVimage: file /usr/diags/ml_xtdigvid/bin/testpattern/tpat625.yuv, xsize = 720,  ysize =
 576
/usr/diags/ml_xtdigvid/bin/dv_memtovid.1754: image buffer size = 829440
/usr/diags/ml_xtdigvid/bin/dv_memtovid.1754: filling buffers.......
Wed Jul 19 02:58:19 BST 2017
/usr/diags/ml_xtdigvid/bin/dv_memtovid.1754: Saving reference filename = /usr/diags/ml_xtdig
/usr/diags/ml_xtdigvid/bin/dv_memtovid.1754: transferring buffers:...100...200...300
PASS: ML_TIMING_625 loopback test with internal genlock passed.
[1]  + Killed               npri -s RR -r 100 /usr/diags/ml_xtdigvid/bin/dv_memtovid -d xt-d
igvid -B 0 -t  ...
================== XTDIGVID_CONFIDENCE SUMMARY ======================
        XTDIGVID board 0:       XT-DIGVID part # 030-1653-003, Rev C),
                                Serial # NAR190
        Test log for board 0:   /usr/tmp/XTDIGVID_logs/xtdigvid_confidence.log0.17-07-19_02.
56
        Ended on:               Wed Jul 19 02:58:36 BST 2017
        Total loops run:        1
        Overall test result:    XTDIGVID board 0 in /hw/node/xtalk/9 passed!
        -> view /usr/tmp/XTDIGVID_logs/test.sum to see this test summary.
 The xtdigvid_confidence script has completed.
