Clearing Out: Everything Must Go - FREE (UK)
Antnee
Unread postby Antnee » Sun Mar 31, 2013 1:01 am
As much as I love them, I haven't powered any of my SGI or Sun on for years, so I'm going to let it all go for free to anyone who collects. Based near Nottingham, England. I have the following:
  • 2x Octane 2 (1x 360, 1x 400, both V6 Pro)
  • External SCSI DVD-ROM (Charcoal)
  • Origin 200
  • Origin Vault (full of drives)
  • SGI GDM-5411 21" monitor
  • Sun Ultra 30
  • Sun Blade 1000
  • Sun GDM-20E20 20" monitor
  • Number of spare FCAL drives for Blade
I'll get photos and exact specs if anyone is interested.
Antnee
Re: Clearing Out: Everything Must Go - FREE (UK)
Unread postby Antnee » Sun Mar 31, 2013 3:56 am
Origin 200 + Vault hinv
    PIMM_2XT5_2M Board: barcode GFH301     part 013-2284-002 rev  A
            IP29 Board: barcode FXX711     part 030-1244-001 rev  H
Location: /hw/module/1/slot/MotherBoard/node/xtalk/8/pci/2
2 180 MHZ IP27 Processors
FPU: MIPS R10010 Floating Point Chip Revision: 2.7
CPU 0 at Module 1/Slot 1/Slice A: 180 Mhz MIPS R10000 Processor Chip (enabled)
  Processor revision: 2.7. Scache: Size 2 MB Speed 180 Mhz  Tap 0x9
CPU 1 at Module 1/Slot 1/Slice B: 180 Mhz MIPS R10000 Processor Chip (enabled)
Main memory size: 512 Mbytes
Memory at Module 1/Slot 1: 512 MB (enabled)
  Disk drive: unit 5 on SCSI controller 0 (unit 5)
  Disk drive: unit 6 on SCSI controller 0 (unit 6)
Integral SCSI controller 3: Version QL1040B (rev. 2), differential
  Disk drive: unit 1 on SCSI controller 3 (unit 1)
  Disk drive: unit 2 on SCSI controller 3 (unit 2)
  Disk drive: unit 3 on SCSI controller 3 (unit 3)
  Disk drive: unit 4 on SCSI controller 3 (unit 4)
  Disk drive: unit 5 on SCSI controller 3 (unit 5)
  Disk drive: unit 6 on SCSI controller 3 (unit 6)
Integral Fast Ethernet: ef0, version 1, module 1, slot MotherBoard, pci 2
Origin 200 base I/O, module 1 slot 1
  PCI Adapter ID (vendor 0x1077, device 0x1020) PCI slot 6
HUB in Module 1/Slot 1: Revision 3 Speed 90.00 Mhz (enabled)
Antnee
Unread postby Antnee » Sun Mar 31, 2013 4:02 am
Octane 2 360MHz hinv
      PM10360MHZ Board: barcode LME623     part 030-1590-001 rev  B
            IP30 Board: barcode LKE040     part 030-1467-001 rev  D
             FP1 Board: barcode MBY848     part 030-0891-003 rev  J
    PWR.SPPLY.ER Board: barcode AAE1110097 part 060-0035-002 rev  A
           ODY32 Board: barcode LKS139     part 030-1403-003 rev  B
1 360 MHZ IP30 Processor
Heart ASIC: Revision F
Main memory size: 1024 Mbytes
Xbow ASIC: Revision 1.4
IOC3 serial port: tty1
IOC3 serial port: tty2
Graphics board: V6
  PCI Adapter ID (vendor 4265, device 5) pci slot 3
indyman007
Unread postby indyman007 » Sun Mar 31, 2013 2:19 pm
PM sent
:Indy: R4600PC 133 MHz
Mac Mini 2.5GHz 8GB RAM
Raspberry Pi
Unread postby foetz » Sun Mar 31, 2013 3:46 pm
very generous, pity i'm too far away :P
mazzinia
Unread postby mazzinia » Tue Apr 02, 2013 4:35 am
Hello,
would you consider shipping ?
Alessandro
Antnee
Unread postby Antnee » Tue Apr 02, 2013 4:36 am
No, sorry. I don't have the packaging for one, never mind the lot. The O200 came on a pallet!
mazzinia
Unread postby mazzinia » Tue Apr 02, 2013 4:43 am
Oh, pity :( , it's a bit I'm looking for an octane 2 (actually an sgi in general) but never been lucky in this area of Italy
Antnee
Unread postby Antnee » Tue Apr 02, 2013 5:56 am
Sorry. If I had the packaging I'd be happy to send it anywhere that people were willing to pay for, but I don't :(
Juda$
Unread postby Juda$ » Wed Apr 10, 2013 9:17 am
Is there anything left, or has it all gone ?
[/img]
Proud Owner of
SGi Octane
Digital Alphastation
Digital Personal Workstation
Sun Microsystems Ultra Enterprise 2
HP B2000
Antnee
Unread postby Antnee » Wed Apr 10, 2013 9:23 am
Technically it's all still remaining, because I've not prepared it all to go, though someone has their name on all of it except the Sun monitor I believe
Juda$
Unread postby Juda$ » Wed Apr 10, 2013 9:27 am
I would only be looking for,
Origin 200
I am only in the area until tomorrow evening though
[/img]
Proud Owner of
SGi Octane
HP B2000
Antnee
Unread postby Antnee » Wed Apr 10, 2013 9:29 am
These things are all reserved. If, by the time they're all prepared and ready to go, the person who has their name on them no longer wants them, then I'll be offering them back out again. Tomorrow evening is far too soon for that I'm afraid, mostly because I'm working every hour God sends at the moment to integrate a vendor system with our own, so I don't have the time to sort them. Sorry.
Juda$
Unread postby Juda$ » Wed Apr 10, 2013 9:33 am
No problem, I will cross my finger !
[/img]
Proud Owner of
SGi Octane
HP B2000
mila
Unread postby mila » Wed Apr 10, 2013 12:11 pm
Oh gosh, I really would love to a second O200 and connect them.
if you will not get rid of the O200 I think Fedex could ship it and fix the packing.
Michael
risk.
