SOLD: [SF Bay Area] Tezro Deskside 4xR16K 700MHz
Unread postby nekonoko » Fri Sep 02, 2011 9:35 am
I have a loaded Tezro deskside for sale; asking $850 obo. If there are no local people interested I may considering putting it on eBay in a week or two. Located in Pleasanton (East Bay, California).
root@Kazehana ~ # hinv -vm
       IP53_4CPU Board: barcode NCG203     part 030-1868-001 rev -C
       WS_INT_53 Board: barcode NCD256     part 030-1881-007 rev -A
      ODY128B1_2 Board: barcode NAV200     part 030-1884-002 rev -D
       XT-DIGVID Board: barcode NBL541     part 030-1927-003 rev  B
             IO9 Board: barcode MTZ009     part 030-1771-005 rev -A
4 700 MHZ IP35 Processors
  Processor revision: 2.1. Scache: Size 4 MB Speed 350 Mhz  Tap 0xc
CPU 1 at Module 001c01/Slot 0/Slice B: 700 Mhz MIPS R16000 Processor Chip (enabled)
CPU 2 at Module 001c01/Slot 0/Slice C: 700 Mhz MIPS R16000 Processor Chip (enabled)
CPU 3 at Module 001c01/Slot 0/Slice D: 700 Mhz MIPS R16000 Processor Chip (enabled)
Main memory size: 4096 Mbytes
Integral SCSI controller 3: Version IEEE1394 SBP2
Integral SCSI controller 4: Version LS1030, low voltage differential
Integral SCSI controller 6: Version SAS/SATA LS1068
  Disk drive: unit 0 on SCSI controller 6 (unit 0)
Integral SCSI controller 5: Version LS1030, low voltage differential
IOC3/IOC4 serial port: tty3
IOC3/IOC4 serial port: tty4
Graphics board: V12
Gigabit Ethernet: tg1, module 001c01, PCI bus 3 slot 1
  PCI Adapter ID (vendor 0x104c, device 0x8024) PCI slot 1
  PCI Adapter ID (vendor 0x104c, device 0xac28) PCI slot 2
  PCI Adapter ID (vendor 0x1000, device 0x0030) PCI slot 1
  PCI Adapter ID (vendor 0x1000, device 0x0054) PCI slot 2
IOC4 firmware revision 79
Dual Channel Display
IP35prom in Module 001c01/Slot n0: Revision 6.211
root@Kazehana ~ # /usr/gfx/gfxinfo -v
        BUZZ version B.2
        PB&J version 1
        128MB memory
                Banks: 4, CAS latency: 3
        DM5 attached to Dual Channel 0
         Monitor 0 type: Unknown
        Dual Channel Display option
         Monitor 1 type: Unknown         Monitor 2 type: Unknown
         Video Format Flags:  (none)
         Sync Disabled
         Using Gamma Map 0
        Channel 2 (physical port 1):
         Video Output: 1280 pixels, 720 lines, 60.00Hz (720P_60)
         Sync Disabled
         Using Gamma Map 0
root@Kazehana ~ # configmon -h
  SEQ            NAME      LOCATION          SERIAL_NUM   PART_NUMBER  REVISION
    0              NA            NA                  NA            NA        NA
    1   MODULE_001c01            NA                  NA            NA        NA
    2              L1        001c01                  NA            NA        NA
    3       IP53_4CPU        001c01              NCG203  030-1868-001        -C
    4       MEMBANK_0        001c01                  NA            NA        NA
    5       MEMBANK_1        001c01                  NA            NA        NA
    6       MEMBANK_2        001c01                  NA            NA        NA
    7       MEMBANK_3        001c01                  NA            NA        NA
    8       MEMBANK_4        001c01                  NA            NA        NA
    9       MEMBANK_5        001c01                  NA            NA        NA
   10          R14000        001c01                  NA            NA        NA
   11          R14000        001c01                  NA            NA        NA
   12          R14000        001c01                  NA            NA        NA
   13          R14000        001c01                  NA            NA        NA
   14              NA        001c01                  NA            NA        NA
   15              NA        001c01                  NA            NA        NA
   16     SCSI_CTLR_3            NA                  NA            NA        NA
   17     SCSI_CTLR_2            NA        PP  07/31/02  DVD-ROM SR-8588      7Z20
   18         CDROM_0            NA                  NA            NA        NA
   19     SCSI_CTLR_0            NA                  NA            NA        NA
   20         DRIVE_1            NA               00SS7  15K REFURBISHED      0126
   21         DRIVE_2            NA            3JY08F46    ST318453LC      2741
   22     SCSI_CTLR_1            NA                  NA            NA        NA
   23     SCSI_CTLR_4            NA                  NA            NA        NA
   24     SCSI_CTLR_5            NA                  NA            NA        NA
   25     SCSI_CTLR_6            NA            H819JYHH  Maxtor 7H500F0      1DN0
   26         DRIVE_0            NA            H819JYHH  Maxtor 7H500F0      1DN0
root@Kazehana ~ # l1cmd "env"
          1.8V    Enabled  10%   1.62/  1.98  20%   1.44/  2.16    1.875
           12V    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.000
        12V #2    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.125
          3.3V    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.492
          2.5V    Enabled  10%   2.25/  2.75  20%   2.00/  3.00    2.613
        12V IO    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.000
        5V AUX    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    5.070
      3.3V AUX    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.268
            5V    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    5.044
  XIO 12V BIAS    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   11.938
        XIO 5V    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    5.044
      XIO 2.5V    Enabled  10%   2.25/  2.75  20%   2.00/  3.00    2.574
  XIO 3.3V AUX    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.285
 IP53 3.3V AUX    Enabled  10%   2.97/  3.63  20%   2.64/  3.96    3.302
   IP53 5V AUX    Enabled  10%   4.50/  5.50  20%   4.00/  6.00    5.044
      IP53 12V    Enabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.000
     IP53 SRAM    Enabled  10%   2.25/  2.75  20%   2.00/  3.00    2.600
     IP53 1.5V    Enabled  10%   1.35/  1.65  20%   1.20/  1.80    1.551
     IP53 VCPU    Enabled  10%   1.13/  1.38  20%   1.00/  1.50    1.297
FAN  0   NODE 1    Enabled         1800         2205
FAN  1   NODE 2    Enabled         1800         2235
FAN  2   NODE 3    Enabled         1800         2205
FAN  3    PCI 1    Enabled         1350         1527
FAN  4    PCI 2    Enabled         1350         1555
FAN  5       HD    Enabled         1620         2812
FAN  6    ODY 1     Active         1299         1814
FAN  7    ODY 2     Active         1299         1748
 0 INTERFACE 0       Enabled    [Autofan Control]    76C/168F   35C/ 95F
 1 INTERFACE 1       Enabled    [Autofan Control]    76C/168F   31C/ 87F
 2 INTERFACE 2       Enabled    [Autofan Control]    76C/168F   33C/ 91F
 3 INTERFACE 3       Enabled    [Autofan Control]    76C/168F   37C/ 98F
 4 ODYSSEY           Enabled    [Autofan Control]    76C/168F   50C/122F
 5 NODE              Enabled    [Autofan Control]    76C/168F   45C/113F
 6 BEDROCK           Enabled    [Autofan Control]    85C/185F   47C/116F
                     Zone Temp     Target    Current   Zone Fan   Curr/Min
Zone Name  State     Sensors       Average   Average   Index      Fan %
Node        Enabled           5,6  62C/143F  46C/114F          0   46%/ 46%
PCI         Enabled       0,1,2,3  45C/113F  34C/ 93F        3,4   57%/ 57%
ODY         Enabled             4  50C/122F  50C/122F          6   67%/ 64%
HD          Enabled             5  40C/104F  45C/113F          5   52%/ 38%
root@Kazehana ~ # l1cmd "serial all"
Local System Serial Number      NVRAM         P1000621
Reference System Serial Number  NVRAM         P1000621
Local Brick Serial Number       EEPROM        NCD256
Reference Brick Serial Number   NVRAM         NCD256
INTERFACE   WS_INT_53       NCD256         030_1881_007          A    00
IO9         IO9             MTZ009         030_1771_005          A    00
ODYSSEY     ODY128B1_2      NAV200         030_1884_002          D    00
SNOWBALL    SNOWBALL_EDGE   NBL541         030_1927_003          B    00
NODE        IP53_4CPU       NCG203         030_1868_001          C    00
IO DGHTR    CHWS_IO_DAUG    NAJ837         030_1875_003          A    00
DIMM 0     CE000000000000000C3BBD00 M3 46L2820ET3-CA0   3E   10.0  N/A
DIMM 2     CE000000000000000C2FA800 M3 47L6423DT3-CA0   3D   10.0  N/A
DIMM 4     CE0000000000000027425B00 M3 47L6510BT0-CA0   0B   10.0  N/A
DIMM 6     no hardware detected
DIMM 1     CE000000000000000C44BD00 M3 46L2820ET3-CA0   3E   10.0  N/A
DIMM 3     CE000000000000000CDEA700 M3 47L6423DT3-CA0   3D   10.0  N/A
DIMM 5     CE0000000000000027435B00 M3 47L6510BT0-CA0   0B   10.0  N/A
DIMM 7     no hardware detected
root@Kazehana ~ # scsicontrol -i /dev/scsi/sc*
/dev/scsi/sc0d1l0:  Disk          CSC150GB15K REFURBISHED 0126
Device is  ready
/dev/scsi/sc0d2l0:  Disk          SGI     ST318453LC      2741
Device is  ready
/dev/scsi/sc2d0l0:  CD-ROM        MATSHITADVD-ROM SR-8588 7Z20
ANSI vers 0, ISO ver: 0, ECMA ver: 0; supports:
Device is  not ready
/dev/scsi/sc6d0l0:  Disk          ATA     Maxtor 7H500F0  1DN0
ANSI vers 5, ISO ver: 0, ECMA ver: 0; supports:  cmdqueing
4130photo
Re: FS: [SF Bay Area] Tezro Deskside 4xR16K 700MHz
Unread postby 4130photo » Fri Sep 02, 2011 10:57 am
I wished there wasn't an ocean between the tezro and my place :( Shipping might be a bit complicated
:Indigo: :Indigo2IMP: :Indigo2IMP: :Octane: :O2: :O200: :Octane2: :Onyx2: :Onyx2: :Onyx2R: :1600SW: :1600SW:
paulfred
Unread postby paulfred » Fri Sep 02, 2011 12:05 pm
Exactly the same what I thought :/
:Fuel: :Octane: :O2: :1600SW:
Apple Mac Pro 1,1, IBM p275, IBM p285, IBM 43p140, Sun Fire 280R, HP C8000, Fujitsu Primepower 250, HP rx4640
MisterDNA
Unread postby MisterDNA » Fri Sep 02, 2011 2:03 pm
Want! But I'm in Utah.
-- I'm a PeeCee and I can kick your ass. --
Slow PeeCee - i7 940 OC 4.1GHz, 20GB DDR3 OC 1.8GHz, 2x1TB WD RAID0, ATI 5870 1GB, 3008WFP
Dev PeeCee - IBM Intellistation A Pro - Dual Opteron 290 2.8GHz, 8GB ECC DDR, 500GB SATA, 8400GS, 2x1800FP
Slow PeeCee Cluster - 30x Opteron 275, 60.5GB RAM, 2.2TB, 2x1.5TB
Octane 2xR12K-300, 1.5GB, 36GB 10K, 73GB 10K, V8
Indigo2 195MHz, 1GB, 36GB, SI
There are 10 kinds of people in the world:
Those who understand Ternary. Those who don't. Those who could give a shit less.
Unread postby SAQ » Sat Sep 03, 2011 9:03 am
You're really culling the herd - -1 Origin350, -1 Tezro, think you already sold the Onyx2...
Did you do the blue keys on the keyboard or was that stock at a certain time?
Unread postby nekonoko » Sat Sep 03, 2011 10:30 am
SAQ wrote:You're really culling the herd - -1 Origin350, -1 Tezro, think you already sold the Onyx2...
I still have the Onyx2 :)
I got that keyboard with the blue keys already installed - it was probably made special for a hardware package (MRI I think).
Intuition
Unread postby Intuition » Sat Sep 03, 2011 8:51 pm
Oh jeez, that is tempting. I am down in Los Angeles.
Any 3d software on the Tezro?
Probably not because I can't remember the Tezro era being sold as 3d workstations. Mostly flame setups.
We actually still have a couple Tezro flame setups here at Digital Domain.
Would love to get it if I could successfully put some Maya on it. Now, how much probability is there of getting a legit Maya license for a Tezro?
Would be fun running the renders across the 4 cpus.
My o2 has maya 3 and 4 on it.
Image O2 - 300mhz
aka Casey Christopher
kais58
Unread postby kais58 » Sun Sep 04, 2011 3:56 am
On maya: I don't know but if you find out let me know, be fun to put that on the O4 and any other 3d software it might be able to run as we've only got blender on it right now.
Intuition
Unread postby Intuition » Wed Sep 07, 2011 11:42 am
Hmm, if I did buy the Tezro, what would shipping cost? Like another $100?
Image O2 - 300mhz
Re: SOLD: [SF Bay Area] Tezro Deskside 4xR16K 700MHz
Unread postby nekonoko » Sat Sep 10, 2011 12:08 pm
Tezro is sold, thanks much!
jsloan
Unread postby jsloan » Mon Sep 12, 2011 9:37 am
Hmmm 4x700 tezro deskside @ less than $1000 ... I like these prices we are establishing here...
