ContrAlto - Alto Emulator from LCM
japes
Unread postby japes » Tue Aug 02, 2016 5:53 pm
http://www.livingcomputermuseum.org/Onl ... Press.aspx
Now you can have an Alto in your PC!
Here's an article mentioning it too: https://techcrunch.com/2016/08/02/livin ... -emulator/
Re: ContrAlto - Alto Emulator from LCM
Unread postby robespierre » Tue Aug 02, 2016 7:51 pm
The Alto is a networked computer, it was much less powerful standalone.
I wonder how much software will actually work without PUP networking support and an infrastructure of network servers?
commodorejohn
Unread postby commodorejohn » Tue Aug 02, 2016 8:07 pm
robespierre wrote:The Alto is a networked computer, it was much less powerful standalone.
It's not "less powerful" like it relies on distributed computing or anything, it's just missing the network features.
Anyway, if this emulates the Ethernet connection, shouldn't it be possible to set up a network of emulators?
Pontus
Unread postby Pontus » Tue Aug 02, 2016 9:30 pm
ContrAlto is an application for modern PCs that simulates the original Xerox Alto, from the graphical display to the Ethernet interface.
Well, it says so in the third paragraf..
Unread postby robespierre » Wed Aug 03, 2016 12:23 am
What I mean is that local file storage is not really enough to run a full environment, due to limitations of both the Diablo drive and the machine size. All programs were typically loaded from the file server. XNS did have distributed naming and stuff like that, so it would be fair to say it relied on distributed computing (just like Appletalk or DECnet)
To run a network of emulators you would need IP tunnel support for PUP
pentium
Unread postby pentium » Fri Aug 05, 2016 6:30 pm
What/s this? No XP support?
What stupidity is put into this emulator to prevent that?
EDITED:
Oh wow, it literally will not run on XP. IT just installs and then says it's not a valid Win32 application. Heresy!
Unread postby ClassicHasClass » Sat Aug 06, 2016 5:19 pm
I think that's what's powering the MAZEWAR exhibit here at VCF XI.
Unread postby robespierre » Wed Aug 10, 2016 7:50 pm
If so, they clearly have a network working.
(You can skip to 2m45s, the forum code doesn't seem to understand time pointers)
japes
Unread postby japes » Fri Aug 12, 2016 2:13 am
They have them networked at LCM too. MAZEWAR was running on emulators and the real deal.
As for why no XP support. Probably compiled 64-bit which was a bit bumpy on XP as a recall. Also it requires .NET 4.6, I recall reading that it was having trouble with a previous version of .NET, it thought it could run but would have a runtime fault. I can't fault an emulator for using the tools the developer knows best. It actually doesn't need Windows and the readme on GitHub says it's rough around the edges but works on Linux/Mac with Mono.
japes
Unread postby japes » Fri Aug 12, 2016 2:18 am
https://github.com/livingcomputermuseum ... /Contralto
Section 4.2 of readme.txt covers Ethernet on the emulator.
Return to “Emulation”
