xmame 0.106 (need some help with MIPSpro)
gijoe77
Re: xmame 0.106 (need some help with MIPSpro)
Unread postby gijoe77 » Sat Mar 21, 2015 2:43 am
diegel wrote:These are my preferred mipspro optimization options:
-O3 -mips4 -TARG:platform=IP35:proc=r16000 -OPT:Olimit=0:roundoff=3:alias=TYPED -INLINE
sweet! thanks mate, gonna plug these in and see where i land!
Unread postby foetz » Sat Mar 21, 2015 3:38 am
don't unless you know what each of them does. you might want something else or have a different machine or a different compiler version etc.
gijoe77
Unread postby gijoe77 » Sat Mar 21, 2015 3:45 am
foetz wrote:don't unless you know what each of them does. you might want something else or have a different machine or a different compiler version etc.
best part of learning is falling down :)
eh.. this part here:
kinda lost me to be honest
Unread postby foetz » Sat Mar 21, 2015 3:54 am
gijoe77 wrote:eh.. this part here:
seems you've not yet checked the manpage. there you'd find nice stuff like:
Olimit=n
Specifies that any routine bigger than n should not be
optimized. If -O2 or greater is in effect and a routine is so
big that the compile speed may be slow, the compiler generates
a message indicating the Olimit value that is needed to
optimize. You can recompile with that value of n. The
-OPT:Olimit=0 option is not recommended for general use.
not gonna paste the roundoff and alias parts :P
diegel
Unread postby diegel » Sat Mar 21, 2015 3:58 am
Since we are talking about mame this should be no problem.
man opt and man inline will explain the options.
gijoe77
Unread postby gijoe77 » Wed Mar 25, 2015 6:47 pm
ok, I just compiled a new xmame.x11 v0.106 using MIPSpro and the following CFLAGS:
CFLAGS = -woffall -O3 -mips4 -TARG:platform=IP35:proc=r16000 -OPT:Olimit=0:roundoff=3:alias=TYPED -INLINE
I added
-LNO:opt=0
only for scramble.c to compile (wasn't able to figure out any other way to get LNO not to die on scramble.c)
I attached the makefile and binary if anyone wants to give it a spin, its an easy 10 more fps than the gcc build for me. I can build a generic mips4 binary if anyone is interested
I'm still trying to figure out the m68k -IPA ld shizm
xmame.x11.106.cc.tar.gz
(18.4 MiB) Downloaded 33 times
makefile.irix.cc.txt
(29.19 KiB) Downloaded 34 times
mopar5150
Unread postby mopar5150 » Thu Mar 26, 2015 8:21 pm
I don't understand most of the conversation but well done none the less! It never ceases to amaze me how much you guys can do with these systems.
:Tezro: :O3x0: :A350:
Return to “Emulation”
