sdlmame 0.149 sent to /incoming. Need testers/feedback.
Axatax
Unread postby Axatax » Wed Aug 14, 2013 3:32 pm
This is an IRIX test build of the most recent SDLMAME. More precisely, it is a build of the latest SDLMESS from these sources, compiled as "messtiny" (only a Coleco console) for testing purposes. Someone will need to move it from /incoming as I don't have anywhere to host it on my end.
I want to get some feedback to make sure I'm on the right track before I get too deep in this. The build of the the complete MAME/MESS takes a long time, so I want to make sure others can reproduce my results before bringing the rest of the systems in and tightening it up.
That said:
1. It is the _latest_ (SDL) MESS, compiled with only one system (Coleco).
2. It works for me.
3. It is absolutey unoptomized. It is built with gcc targeted for mips4.
4. You may need the latest gconf and libORBIT from the current Nekoware.
To test:
(Run ./messtiny -help to get the usual MESS options. You can generate a mess.ini if you'd like.)
1. Place a coleco (BIOS) ROM under ./roms/coleco/coleco.rom
2. Start messtiny as such: ./messtiny coleco -cart ./name_of_your_cartridge_image
If you're familiar with running MAME/MESS, all the paths assignments, etc. for the various pieces are the same. Let me know how it works.
:Octane2: Dual R14K@600MHz, 2GB RAM, V12, 1x72GB HDD
:O2: R10K@175MHz, 512MB RAM, 1x72GB HDD
:Cube: 68040@33MHz, 128MB RAM, NeXTdimension 32MB, 2x 4.3GB HDD
...And lots of other UNIX-like systems for which there is no icon.
Axatax
Full SDL MAME available -- Need testers
Unread postby Axatax » Thu Aug 15, 2013 9:05 pm
(EDIT: Sorry, - This should have been a reply to my last MESS thread @ viewtopic.php?f=15&t=16727919) --
I have uploaded a full MAME build to /incoming. All systems are in place. This now has all non-SGI assembler portions ported to MIPS, and is running like a champ on my Octane with the OpenGL/SDL target. Still need some testing and feedback.
This was a heavily requested port judging by a search of the forum. Need to know if there is still interest in this to pursue packaging this for Nekoware.
I need some advanced testing due to the size of these programs and the build time required. I wouldn't mind some time on a large-ish Origin to do some builds (it takes approx ~16 hours to build the whole package [MAME/MESS] on a dual 600MHz Octane with gmake -j3).
Thanks.
Re: Full SDL MAME available -- Need testers
Unread postby ClassicHasClass » Fri Aug 16, 2013 7:02 am
Nice. I'll try to take a look at this when I have some time this weekend. Which specific version of MAME?
cris_adder
Unread postby cris_adder » Sat Aug 17, 2013 8:02 pm
Great...!!!
gijoe77
Unread postby gijoe77 » Sun Mar 15, 2015 12:47 pm
Hey this is exactly what I've been looking for - can't seem to find it - can someone point me in the right direction?
Unread postby foetz » Sun Mar 15, 2015 2:08 pm
Axatax wrote:(EDIT: Sorry, - This should have been a reply to my last MESS thread @ viewtopic.php?f=15&t=16727919) --
sorted :-)
Unread postby nekonoko » Sun Mar 15, 2015 6:49 pm
gijoe77 wrote:Hey this is exactly what I've been looking for - can't seem to find it - can someone point me in the right direction?
I think I found the file in my archives - I moved it to ftp://ftp.nekochan.net/pub/downloads/contrib/axatax
gijoe77
Re: sdlmame 0.149 sent to /incomming. Need testers/feedback.
Unread postby gijoe77 » Mon Mar 16, 2015 11:35 am
thanks Neko,
ok, well, so this wasn't a newer mame which is what I was really looking for, but I used to love my Coleco, but ran into some lib issues, not too sure how to tackle it - pointers anyone?
bash-4.3# ldd  messtiny
        libSDL-1.2.so.1  =>      /usr/nekoware/lib/libSDL-1.2.so.1
        libfontconfig.so.2  =>   /usr/nekoware/lib/libfontconfig.so.2
        libSDL_ttf-2.0.so.1  =>  /usr/nekoware/lib/libSDL_ttf-2.0.so.1
        libgtk-x11-2.0.so.1  =>  /usr/nekoware/lib/libgtk-x11-2.0.so.1
        libgdk-x11-2.0.so.1  =>  /usr/nekoware/lib/libgdk-x11-2.0.so.1
        libatk-1.0.so.1  =>      /usr/nekoware/lib/libatk-1.0.so.1
        libgdk_pixbuf-2.0.so.1  =>       /usr/nekoware/lib/libgdk_pixbuf-2.0.so.1
        libpangocairo-1.0.so.1  =>       /usr/nekoware/lib/libpangocairo-1.0.so.1
        libpango-1.0.so.1  =>    /usr/nekoware/lib/libpango-1.0.so.1
        libcairo.so.3  =>        /usr/nekoware/lib/libcairo.so.3
        libgmodule-2.0.so.1  =>  /usr/nekoware/lib/libgmodule-2.0.so.1
        libgobject-2.0.so.1  =>  /usr/nekoware/lib/libgobject-2.0.so.1
        libgthread-2.0.so.1  =>  /usr/nekoware/lib/libgthread-2.0.so.1
        libglib-2.0.so.1  =>     /usr/nekoware/lib/libglib-2.0.so.1
        libintl.so.9  =>         /usr/nekoware/lib/libintl.so.9
        libgconf-2.so.5  =>      /usr/nekoware/lib/libgconf-2.so.5
        libORBit-2.so.1  =>      /usr/nekoware/lib/libORBit-2.so.1
13713: 10:23:46 messtiny: rld: Fatal Error exit/longjmp: Cannot Successfully map soname 'libstdc++.so.7' under any of the filenames /usr/nekoware/lib/libstdc++.so.7:/opt/build/pango-1.12.4/pango/.libs/libstdc++.so.7:/usr/nekoware//lib/libstdc++.so.7:/work/pango-1.28.4/pango/.libs/libstdc++.so.7:/lib32/libstdc++.so.7:/usr/lib32/libstdc++.so.7:/usr/freeware/lib/libstdc++.so.7:/usr/local/lib/libstdc++.so.7:/usr/lib32/internal/libstdc++.so.7:/opt/lib32/libstdc++.so.7:/usr/nekoware/lib/libstdc++.so.7.7:/opt/build/pango-1.12.4/pango/.libs/libstdc++.so.7.7:/usr/nekoware//lib/libstdc++.so.7.7:/work/pango-1.28.4/pango/.libs/libstdc++.so.7.7:/lib32/libstdc++.so.7.7:/usr/lib32/libstdc++.so.7.7:/usr/freeware/lib/libstdc++.so.7.7:/usr/local/lib/libstdc++.so.7.7:/usr/lib32/internal/libstdc++.so.7.7:/opt/lib32/libstdc++.so.7.7:
13713:messtiny: rld: Fatal Error: Cannot Successfully map soname 'libstdc++.so.7' under any of the filenames /usr/nekoware/lib/libstdc++.so.7:/opt/build/pango-1.12.4/pango/.libs/libstdc++.so.7:/usr/nekoware//lib/libstdc++.so.7:/work/pango-1.28.4/pango/.libs/libstdc++.so.7:/lib32/libstdc++.so.7:/usr/lib32/libstdc++.so.7:/usr/freeware/lib/libstdc++.so.7:/usr/local/lib/libstdc++.so.7:/usr/lib32/internal/libstdc++.so.7:/opt/lib32/libstdc++.so.7:/usr/nekoware/lib/libstdc++.so.7.7:/opt/build/pango-1.12.4/pango/.libs/libstdc++.so.7.7:/usr/nekoware//lib/libstdc++.so.7.7:/work/pango-1.28.4/pango/.libs/libstdc++.so.7.7:/lib32/libstdc++.so.7.7:/usr/lib32/libstdc++.so.7.7:/usr/freeware/lib/libstdc++.so.7.7:/usr/local/lib/libstdc++.so.7.7:/usr/lib32/internal/libstdc++.so.7.7:/opt/lib32/libstdc++.so.7.7:
bash-4.3#find / | grep libstdc++
/usr/nekoware/gcc-4.7/lib64/libstdc++.a
/usr/nekoware/gcc-4.7/lib64/libstdc++.a-gdb.py
/usr/nekoware/gcc-4.7/lib64/libstdc++.la
/usr/nekoware/gcc-4.7/lib32/libstdc++.a
/usr/nekoware/gcc-4.7/lib32/libstdc++.a-gdb.py
/usr/nekoware/gcc-4.7/lib32/libstdc++.la
/usr/nekoware/lib/gcc/mips-sgi-irix6.5/3.4.6/mabi=64/libstdc++.a
/usr/nekoware/lib/gcc/mips-sgi-irix6.5/3.4.6/mabi=64/libstdc++.la
/usr/nekoware/lib/gcc/mips-sgi-irix6.5/3.4.6/mabi=32/libstdc++.a
/usr/nekoware/lib/gcc/mips-sgi-irix6.5/3.4.6/mabi=32/libstdc++.la
/usr/nekoware/lib/gcc/mips-sgi-irix6.5/3.4.6/libstdc++.a
/usr/nekoware/lib/gcc/mips-sgi-irix6.5/3.4.6/libstdc++.la
bash-4.3#
Unread postby foetz » Mon Mar 16, 2015 3:39 pm
you simply don't have a shared libstdc++
gijoe77
Unread postby gijoe77 » Mon Mar 16, 2015 5:43 pm
Hi foetz,
I'm pretty newb with the lib/gcc stuff, I've been looking through the nekoware and I'm at a loss of where I can find it (seems the gcc packages have libstdc++.a). Is this a library that comes in nekoware or is this something that one must compile themselves?
Unread postby foetz » Mon Mar 16, 2015 5:59 pm
i have no idea which nekoware package has that specific file. maybe we should have an index for such cases and also we usually do add something like -gcc to the name of all contributions that are built with gcc
Unread postby nekonoko » Mon Mar 16, 2015 6:46 pm
Yeah, I'm pretty sure neko_gcc has that library statically linked so people won't run into situations like this. I'd guess the package was compiled with a different gcc distro/self-compiled version.
diegel
Unread postby diegel » Tue Mar 17, 2015 12:29 am
nekonoko wrote:Yeah, I'm pretty sure neko_gcc has that library statically linked so people won't run into situations like this.
This is correct for gcc 4.7 but not for gcc 3.4. Installing neko_gcc-3.4.6 and set a proper library path should fix the problem.
gijoe77
Re: sdlmame 0.149 sent to /incoming. Need testers/feedback.
Unread postby gijoe77 » Tue Mar 17, 2015 11:29 am
Hi diegel,
I just double checked and I have neko_gcc-3.4.6 installed (except for the java support stuff), I also did a file search on the distro in swmgr and there were 6 matches, all of which are installed (as per screenshot). I included a screenshot just incase there is something really silly im doing here
diegel
Unread postby diegel » Tue Mar 17, 2015 11:57 am
gijoe77 wrote:I just double checked and I have neko_gcc-3.4.6 installed
Sorry I was wrong. I was sure I had this problem in the past, but possibly I see the missing library problem during a build process. In this case I guess it is a tgcware gcc he was using. You can find tgcware packages at http://jupiterrise.com/tgcware/irix6.2/stable/ tgcware is build for Irix 6.2, but it should run on 6.5 also. You can find a libstdc++ library in libstdcxx_7-4.3.3-1.tgc-irix6.2-mips3-tgcware.tardist for example.
Return to “Emulation”
