AIX 1.3
bmnb1234
AIX 1.3
Unread postby bmnb1234 » Tue Sep 25, 2007 7:33 am
I saw Aix 1.3 the vetusware doses any one have any experience with it can install in on a normal Pc or do I need a ps2 to get working
:mrgreen:
porter
Re: AIX 1.3
Unread postby porter » Tue Sep 25, 2007 10:51 am
bmnb1234 wrote:I saw Aix 1.3 the vetusware doses any one have any experience with it can install in on a normal Pc or do I need a ps2 to get working
I would try and get an original PS/2.
have you seen http://ps-2.kev009.com:8081/ohlandl/AIX_1-3/AIX_Index.html?
chatuser
Re: AIX 1.3
Unread postby chatuser » Wed Sep 26, 2007 1:18 pm
I have tried to install AIX 1.3 in vmware but it doesn't work, you need an original system.
It's easier to buy an IBM Power System on eBay to enjoy AIX.
:Indy: Indy R4400 150 MHz, 256 MB, Indy 24-bit, IRIX 6.5.22m/Debian GNU/Linux
:Octane2: Octane2 R12K 400 MHz, 1 GB, VPro V6, IRIX 6.5.30
IBM 44p 170 POWER3-II 400 MHz, 1 GB, Matrox G200 (GXT130P), AIX 5.3/Debian GNU/Linux
:hpserv: HP C3750+C3600 2GB, HP-UX 11v1/Debian GNU/Linux
Re: AIX 1.3
Unread postby SAQ » Wed Sep 26, 2007 4:27 pm
chatuser wrote:It's easier to buy an IBM Power System on eBay to enjoy AIX.
NB that AIX/6000 (v3 and above) are a bit different from AIX v1.x (and internally substantially different from AIX/RT v2).
If you really want to run AIX v1 get a PS/2- you're just asking for trouble to try to build a almost-exact-clone of a PS/2 from third-party parts. A little m80 or above is pretty cheap now.
bmnb1234
Re: AIX 1.3
Unread postby bmnb1234 » Thu Sep 27, 2007 8:16 am
do you think I can get away using Bochs pc emulator?
:twisted:
porter
Re: AIX 1.3
Unread postby porter » Thu Sep 27, 2007 11:26 am
To be fair, compare with Linux support for MCA.
Re: AIX 1.3
Unread postby SAQ » Thu Sep 27, 2007 6:11 pm
I'm not complaining- no one would expect to pick up a PlayStation or other MIPS-based system and run IRIX on it, now would you? Why should IBM go out of their way to support their competitor's machines?
PS/2s are pretty common and bulletproof (just make sure you get a SCSI model- a few of them were ESDI and that can be difficult unless you have a well-stocked garage).
porter
Re: AIX 1.3
Unread postby porter » Mon Oct 01, 2007 2:43 am
http://web.cecs.pdx.edu/~trent/gnu/bull/16/gnu_bulletin_19.html
Any idea if a recent (eg gcc 2.7.2 upwards) is available for "aixps2" or "AIX/386"?
porter
Re: AIX 1.3
Unread postby porter » Tue Oct 02, 2007 9:22 am
This looks promising...
In "PTF0024/U436295.ps"
IX45072 Support added for PS/2 9577 - Models 76i, 76s, 77i and 77s.
I have a 76i (IDE only) working it's way to me, I was wondering if I should get an MCA SCSI card.
porter
Re: AIX 1.3
Unread postby porter » Sun Oct 07, 2007 3:30 am
# uname -a
AIX aixps 1 3.0 i386
porter
Re: AIX 1.3
Unread postby porter » Mon Oct 08, 2007 1:55 am
Installation on a 76i has gone okay except I can't boot from a kernel on the IDE harddisk. Bios is at version 8. No SCSI adapter.
The 0024 maintenance disk happily lists the following
hd5       /aixps2/tmp
hd4
hd3       /
hd2   bootable /aixps2
hd1       /u
the installation of 1.3 went okay, then able to add the U436295 from PTF0024.
However booting, either from the harddisk directly, or by trying to boot from harddisk using the 0024 SCSI boot disks gives the following
Ldlook: not a directory
/boot not found
bload: can't open /boot
boot strap panic: Unexpected exit in boot code
There is a file called "boot" in the root of "hd2".
Any clues? Do I really need to be using a SCSI adapter and SCSI hard disk?
pentium
Re: AIX 1.3
Unread postby pentium » Wed Oct 24, 2007 11:47 pm
Will there be any problems installing AIX 1.3 on a Model 55 SX with a PureData network card and a 160Mb ESDI drive?
I have one kicking around and I find it's not good enough for OS/2.
porter
Re: AIX 1.3
Unread postby porter » Thu Oct 25, 2007 12:21 am
Give it a spin. I'm waiting for some SCSI kit.
pentium
Re: AIX 1.3
Unread postby pentium » Thu Oct 25, 2007 4:40 pm
porter wrote:Give it a spin. I'm waiting for some SCSI kit.
:evil: I just came home and as soon as the ol' 55SX was setup I turned it on and was greeted with a cmos reset and a clock that won't hold time. Yep, time to install an external battery on the Dallas chip.
We will have to wait now. I'm far too busy to do that and I'm short a coin-type battery holder (Tape does not seem to hold the wires well).
On the other hand I looked at that Vetusware download and it looks pretty good. It even states my system is compatible (according to documentation). Now I just need to find out how to image those .img files to a floppy with windows. Every other system I own that could do this is either down or needs parts. Rawrite should do the trick and I think I also have a graphical alternative that should work too. Good thing I have 200+ floppies sitting around.
I also looked around and it seems that almost all the emulators have trouble running AIX 1.3. PS/2 systems are not that uncommon.
porter
Re: AIX 1.3
Unread postby porter » Thu Oct 25, 2007 5:00 pm
It's worth reformatting the floppies first and junking the ones which have bad blocks or seem to take longer than normal.
http://www.walshcomptech.com/comp_coll.htm
Return to “Emulation”
