indy ram
waldo
indy ram
Unread postby waldo » Tue Feb 11, 2003 7:02 pm
indytech says that 72-pin ram with tin leads will "reportedly" lead to corrosion and you ought to use ram with gold leads. anybody run tin ram? any problems?
cuz.. yeah. maxing my indy's ram would be fun.
Re: indy ram
Unread postby nekonoko » Tue Feb 11, 2003 11:31 pm
waldo wrote:indytech says that 72-pin ram with tin leads will "reportedly" lead to corrosion and you ought to use ram with gold leads. anybody run tin ram? any problems?
Sure, I've used tin lead RAM for years in various SGI machines. There was some discussion about it a while back in comp.sys.sgi.* and no-one who used tin-lead has ever experienced any corrosion problems.
akimmet
Re: indy ram
Unread postby akimmet » Wed Feb 12, 2003 5:26 am
Corrosion does occour, but it took more than 5 years to happen to me, and was fixed by reseating it (however it was gold simms in a tin socket). So just rember to reseat your simms every five years or so, and your set! :D
Shtoink
Unread postby Shtoink » Fri Feb 14, 2003 6:57 pm
Agreed, it does take quite a bit of time for any corrosion to occur. Your environmet can also affect this as well, depending upon the humidity and amount of air polution and such.
